Old 12-06-2014, 10:19 AM   #15
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I was going to have to get one of the Furion connectors replaced anyway- the LED doesn't work on one of them.
It sounds like it's not defective parts, but improper torque on the lugs when installed.
2012 Dodge Durango Hemi/AWD
Old 12-06-2014, 12:24 PM   #16
Tincampers's Avatar
Sneedville , Tennessee
The way I interpret the descriptions in the supporting documents, Furion, had a bad batch of plugs with bad terminal screws/bolts that would not stand up to proper tightening which results in the loose connections.
Tincampers is offline   Reply With Quote
Old 12-06-2014, 01:19 PM   #17
Wayne&Sam's Avatar
Images: 21
Right Mrprez. I missed that.
Old 12-06-2014, 01:20 PM   #18
Wayne&Sam's Avatar
Images: 21
Originally Posted by gtc6452 View Post
can someone remind me how to read the vin number?
Left to right?
Old 12-06-2014, 02:04 PM   #19
Tincampers's Avatar
Street side front corner right behind the rock guard.
Left to right?
Oooh you're bad!
This recall is not VIN specific. It affects all trailers made between Nov/13 and Aug/14. See above for specific dates.
Old 12-06-2014, 02:43 PM   #20
Durango , Colorado
Well mine went onto the line on Sept. 29, 2014. So I guess I am in the clear. I also haven't received a letter from Airstream.
Thank you for the info and links, mrprez.
RVDreamer is offline   Reply With Quote
Old 12-06-2014, 02:52 PM   #21
gtc6452's Avatar
2015 27' Flying Cloud
2011 30' International
mooresburg , Tennessee
I can figure out the year, which number is the month?
gtc6452 is offline   Reply With Quote
Old 12-06-2014, 03:46 PM   #22
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Try this.
http://www.airstream.com/wp-content/...-post-1980.pdf
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 12-06-2014, 03:55 PM   #23
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Recall notice
I wonder if it is possible for an owner to determine if a problem exists. I will most likely check at Out of Doors Mart to determine if I need to pull the trailer out there or if I can simply inspect the connection myself. I have the 50 Amp connection.
Ms. Tommie Lauer
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 12-06-2014, 04:16 PM   #24
gtc6452's Avatar
the 50 amp is a different maker. not a furion.
Old 12-06-2014, 04:17 PM   #25
Silverbee's Avatar
2015 28' Flying Cloud
2012 25' Flying Cloud
2007 20' Safari SE
Fuquay Varina , North Carolina
Ms. Tommie Lauer
Thanks Tommie. We will wait to see the response you get and not call ODM unless we need to take the AS over there.
Silverbee is offline   Reply With Quote
Old 12-06-2014, 04:17 PM   #26
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Our 50 amp was made by Furrion.
Old 12-06-2014, 05:24 PM   #27
gtc6452's Avatar
After re reading the posts. it seems to be a 30 amp furion problem.
Old 12-06-2014, 05:30 PM   #28
Central , Mississippi
Recall notice
Crap.
I gotta figure out the manufacture date .
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
NHTSA Argosy recall notice bkahler Argosy Motorhomes 3 10-22-2007 12:45 PM
2004 Recall Notice andyfuson Axles 91 10-18-2005 08:33 PM
Recall notice~ 53flyingcloud LP Gas, Piping, Tanks & Regulators 1 01-02-2005 07:51 AM
Hey, anybody notice... CanoeStream Off Topic Forum 1 01-26-2004 12:59 PM
