How do I show a earlier post in my reply giving credit to whom I'm answering?
These are usually in a shaded box so people will know what I am referring too.
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
Iv'e seen more than one quote used, how is that accomplished??
When you are using the edit window, you copy the “Square Bracket quote” and “Square Bracket /quote” tags and paste the in the appropriate places. It helps if you know html, which is similar. They are start and stop tags. Then, you just put your comments in between. That’s how I put in the multiple replies on this thread: Burned 310 classic moho - questions.
__________________ Vaughan
A sixth sense (I lack the other five) tells me that I am in serious difficulties.Oscar Levant
Gee, we had a similar question yesterday. That makes finding previous posts easy. Thanks! The discussion started here.
so I'll start here!! Went to the St. Cloud RV show and saw some neat stuff. A flat panel TV was mounted in the cupboard door, so you could just open it and still use the space behind it. Another flat TV was mounted on a swivel in the bedroom/living room divider so you could face it into the room that you wanted. 2 questions?? Does one really need 3 TV's to go camping? and in Minnesnowda, where we set low temp records every winter,would not these TV's freeze if left in unheated storage?? joqin wants to know!! happy camping.
I'll try, sounds easy!
Originally Posted by overlander63 Instead of "reply," click "quote", as I just did.
It helps if you click in the right box! The question of two Quotes is still up in the air!
Paul
I'm beginning to see whats possible!
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
Originally Posted by vswingfield When you are using the edit window, you copy the “Square Bracket quote” and “Square Bracket /quote” tags and paste the in the appropriate places. It helps if you know html, which is similar. They are start and stop tags. Then, you just put your comments in between. That’s how I put in the multiple replies on this thread: Burned 310 classic moho - questions
Did I do it??????
Looks like you are missing the commands...you need the "[" & [/] around the word "QUOTE" at the begining and end. Should look like the .jpg image below. If you put an "=" then someone's name it will show at the beginning of the quote.
Make sense?
Example one:
"I'll know where I am when I get there"
Example two:
If you want multiple quotes, just use the [-quote-] or the [-quote=name-] command before and the [-/quote-] comand after (without the "-") before & after each section you want quoted.
Shari
__________________ Vintage Airstream Club - Past President 2007/2008 WBCCI #1824 - DenCO Unit Past President (2005) AIR #30 - Join Date: 2-25-2002
Hi, Support Folks,
I am missing posts that people have added to my thread since 6/8. Today, I see that someone added a post this afternoon, but it does not appear in the thread.
The last post I see -- and I have hit "refresh" on the browser a few times to be sure my browser isn't loading a previously cached page -- is 6/8/08 at 5:07 a.m.
I see in my User CP where my thread is subscribed, that someone posted today at 3:36 p.m.
Please advise me on how to find the missing posts since 6/8/08.
In your user cp change your settings a bit:
Click on user cp (upper blue bar)
Find edit options on the left side menu.
Scroll down and change the thread display options to linear, newest first.
Then scroll down and hit save.
Holler if you need more help. I see 68 posts on your thread.
__________________ 77 Argosy Minuet, 6 metre | 77 Argosy 24, Rear door AIR # 3181 | WBCCI # 5575
