Old 08-25-2007, 10:46 AM   #1
Administrator
Andy R's Avatar
1961 16' Bambi
Dallas , Texas
Images: 13
NOTICE: Switching to a new network
I wanted to let you all know that I will be switching the site to a new network today. The old provider has been giving some members very slow connection speeds for the last couple of weeks (read more about this issue here). We will be moving to a more sophisticated network with more backbone providers and route optimized technology to optimize the speed at which you connect to our server.
This switch should cause very little downtime but a DNS change will be required. Our DNS is set to refresh every 20 minutes so no one should be down longer then that. For most people the downtime will be significantly less.
I will post an update after the switch is complete and then solicit your feedback on site speeds after the changes. As always, thanks for your patience and continued participation in our community.
Regards,
AIR # 2 - 1961 Bambi - Jeep Cherokee
Campground Reviews: Submit and review campgrounds around the US
Andy R is offline   Reply With Quote
Old 08-25-2007, 10:48 AM   #2
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Thanks Andy for your constant efforts in upgrades, etc.
Dave
Fyrzowt is offline   Reply With Quote
Old 08-25-2007, 10:58 AM   #3
SaabLover's Avatar
Almost Always Sunny Sarasota , Florida
Images: 12
As long as there is injustice, whenever a Targathian baby cries out, wherever a distress signal sounds among the stars, we'll be there. This fine ship, this fine crew. Never give up... and never surrender.
Keep up the good work Andy
SaabLover is offline   Reply With Quote
Old 08-25-2007, 11:00 AM   #4
Maybricks's Avatar
1962 19' Globetrotter
1960 22' Safari
Stamford , Rutland UK
Send a message via Yahoo to Maybricks
Thank you for the warning and about caring enuf to do something about the problems we've been having!
www.vintage-americana.co.uk
+44 (0)7984 662 532
Maybricks is offline   Reply With Quote
Old 08-25-2007, 01:38 PM   #5
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
I guess I was one of the one's that got caught between the provider change over. Couldn't get in for about 45 minuets. But, all is now fine in the land of Airstream !
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 08-25-2007, 02:17 PM   #6
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
That quote from Galaxy Quest could go in either direction...
Old 08-25-2007, 02:22 PM   #7
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Andy...FYI...
I continue to get the "404 - Not Found" message whenever I attempt to cast a ballot in the polls on the home page.
Thought you should know.
TB
Old 08-25-2007, 02:24 PM   #8
Well Preserved
1993 21' Sovereign
Originally Posted by TBRich
Andy...FYI...
TB
Many of the current polls, aren't. We know about it, but it's been a low priority, compared to keeping the other stuff going.
Old 08-25-2007, 03:07 PM   #9
Maybricks's Avatar
1960 22' Safari
My id bit on the left hand side is sorta squished when i go back and view a reply i have just posted.... not sure if that makes sense! Not a prob but thought it might be a symptom of summat else
+44 (0)7984 662 532
Old 08-25-2007, 03:49 PM   #10
Well Preserved
1993 21' Sovereign
Sharon, I have seen this before on my computer, and it seems to be a browser problem. Last time I upgraded, and changed the screen resolution, the problem stopped.
Old 08-25-2007, 05:53 PM   #11
CanoeStream's Avatar
St. Cloud , Minnesota
Things seem to be running a bit smoother now than between 4:00 & 6:00PM CDT. Everybody else doing okay? Would somebody from each corner of the country chime in? Thanks!
5 meter Langford Nahanni
Old 08-25-2007, 06:14 PM   #12
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I could not get to the site untill an hour ago, It is running ok, but sometimes it seems to hang opening a thread from the NEW POST screen. If I select it again, it opens fine....
Phoenix, AZ
Richard
Old 08-25-2007, 06:26 PM   #13
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Ditto what Richard said... Actually I was on line at the site one second and it went down in the next second...off about an hour here... It's still a bit sluggish when I click a new thread..but if I hit "stop" and try again, it goes right through...
Tucson, AZ...
TB
Old 08-25-2007, 06:34 PM   #14
USN/LAPD Retired
Running smooth here on the West Coast.
R/
Rick
AIR #: 8129
Switching bath and bed areas. reece1107 Plumbing - Systems & Fixtures 11 02-05-2017 08:58 AM
DIY Network Overlander Restoration Series lubbockgolf Airstream "In the News" 18 06-15-2012 06:06 PM
Calling all network admins Part 2 Silvertwinkie Off Topic Forum 18 05-17-2007 02:24 PM
DIY Network Show. ssww Our Community 7 11-27-2005 12:58 PM
Dish Network vs Direct TV gwsullivan Electrical - Systems, Generators, Batteries & Solar 36 01-17-2005 02:49 PM
