08-08-2004, 09:30 PM
Administrator
1961 16' Bambi
Dallas
New thumbnail feature...
I will be processing all attachments to make thumbnails in rder to reduce the bandwidth we are using. so look for that change in the next couple of days...
08-09-2004, 05:53 AM
That sounds like a major improvement.
Are you going to have to go back and change each picture individually? That seems like a lifelong task . Or is there a way you can make em all change to thumbnails with one sweep of the wand?
Any idea of how many pictures are posted on the forums? (Not counting the photo forum).
08-09-2004, 07:01 AM
Administrator
1961 16' Bambi
Dallas
7,000+ photos (not counting the ones at AirstreamPhotos.com)
They should all be done now. If they are not, let me know and I will sweep the wand again. My search engine submission software might have stopped the process?
08-09-2004, 07:15 AM
IT'S DONE and WORKS!
08-09-2004, 07:39 AM
Retired Moderator
1992 29' Excella
madison
, Wisconsin
added benefit!
for those of us on dial up, faster page loading!
i like it!
works well for media rich posts i recheck frequently. saves time.
thanks again for the hard work and dedication to this site andy!
john
you call them ferrets, i call them weasels.
08-11-2004, 09:44 AM
5 rivets, 1 loose screw
1966 20' Globetrotter
Saginaw County
, Michigan
Well done Andy
Faster loading, less bandspace, no side scrolling and multiple images at a glance.
I like it!
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
08-11-2004, 11:48 AM
I may have discovered a possible problem with the thumbnail format O.H. .
I noticed that a drawing that is now in thumbnail, and was very readable before, now is somewhat blurred when enlarged from thumbnail.
The blurring is most evident in the labelings that are part of the drawing.
Is there any reason that when "re-blown" to original size that there would be a loss of clarity? (Assuming clarity originally of course).
The drawing I refer to is at Post #1 of the following thread:
http://www.airforums.com/forum...ad.php?t=13045
08-11-2004, 12:19 PM
Sounds like the JPEG compression is set too high. Perhaps the original images were resampled, along with the thumbnails. Without going into a lot of detail, everytime you save or resave a JPEG and select a compression setting other than "lowest", you'll get that...
08-11-2004, 12:29 PM
Saginaw County
, Michigan
That drawing has to be enlarged twice to see the full size image.
One click enlarges it to 378x378 (illegible). A second click enlarges it to full size 640x640 (very legible).
I don't know the technical term, I just know that's how it works for me.
Rog
08-11-2004, 01:02 PM
Just an old timer...
2004 22' Interstate
Tipton
, Iowa
Uh... Rog... I think the technical term is enlarging it twice so you can see the full-size image...
Roger
havin' to fix my broken Airstreams since 1987...
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N DODGE Sprinter
08-11-2004, 01:05 PM
1968 22' Safari
1976 27' Overlander
Newport
Noticed it last night when I was searching
I found it to be a nice feature, as mentioned before, to be able to see them all at a quick glance...
It was the 'now let's see you' thread, which would have taken forever to scroll through,a dn find what I needed.
Ron
Ron ... now in Newport, Washington
[font=Impact][font=Arial Black]
08-11-2004, 01:08 PM
Saginaw County
, Michigan
Roger
Thanks Roger. It's nice to know we can always count on you for the techy stuff.
Rog
08-11-2004, 11:58 PM
The new thumbnails are really great! Helps a lot for pictures that were really too big to be posted. Saves a lot of thread real estate!
Thanks Andy!
Cheers, Linda
08-12-2004, 07:43 AM
Contributing Member
Austin (Hays County)
Strange
I get everything but the thumbnails with Netscape; just an empty box where the thumbnails should be. I wonder whether my high firewall settings are causing this.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
08-12-2004, 09:11 AM
I'm using Netscape, tho on a mac.
Cheers, Linda
08-18-2004, 11:57 AM
vancouver
How come some attached pictures are left large while others get the thumbnail treatment?
check pix on post 1 http://www.airforums.com/forum...ad.php?t=13333
and post 16 and 20 on http://www.airforums.com/forum...t=13363&page=1
Aluminauts
2003 34' Airstream Classic
2007 Chevy Silverado 2500HD
Allison Duramax 4X4
Hensley Arrow hitch
Kodiak / Actibrake Disc Brakes
Tekonsha Prodigy brake controller
Doran Pressure Pro
WBCCI #2984 Air # 4173
08-18-2004, 12:25 PM
Just a member
1978 28' Argosy 28
Lutz
It has to do with how the pictures were inserted into the post.
Using an img tag allows it to post bigger. The image is not hosted here and does not use the forum bandwidth. If the image is posted in the thread then it is using space and bandwidth on the forum so it shows in a thumbnail style. It all depends on how you do it.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
08-18-2004, 12:47 PM
vancouver
Thanks, I'll mark this a something learned.
Aluminauts
Allison Duramax 4X4
Hensley Arrow hitch
Doran Pressure Pro
