Old 10-09-2013, 03:57 PM   #225
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I have been having these problem a little more than a month:
1. Sometimes, after I view a thread then hit the back button the window goes blank then displays a notice that is something like "this page cannot be displayed". After that I cannot get immediately back into the forum, this same message displays every time I try. After I have opened a few other websites I can come back and get into the forum. This only happens on the Airforum.
2. In the middle of typing a response to a post, the page will close. The "this page cannot be displayed" message, same thing happens as above.
3. Similar issues when I view the classifieds.
Since this only happens in the Airforum, I'm wondering if there is something an administrator can help me with. I am accessing with my Dell laptop using Window 7 and internet explorer, currently updated.
Alan
Old 10-09-2013, 07:29 PM   #226
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
WA, try dumping your cache and dumping your cookies (Internet Options -> General -> Browsing History). Sometimes that helps with netstipation (but sometimes not). Let us know what you find, ok?
Lynn
WBCCI 21043
eubank is online now   Reply With Quote
Old 10-09-2013, 08:44 PM   #227
Ag&Au's Avatar
Port Orchard , Washington
I used to have periods of annoyances like these. However I have had none since upgrading to IE 10. Just an idea..
Download Internet Explorer 10 - Microsoft Windows
Ken
Also certain free ad blockers can cause this type of behavior.
Old 10-09-2013, 09:36 PM   #228
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Lynn
I have settings so that browsing history and cookies dump every time I reboot. I have also done this manually.
That's not the problem.
Alan
Old 10-09-2013, 09:45 PM   #229
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Ken
I'm also using IE10, with Windows set to update automatically.
No ad blockers
Alan
Old 10-10-2013, 08:18 AM   #230
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Alan, have you tried simply logging out of Airforums and then re-logging in?
Lynn
WBCCI 21043
Old 10-10-2013, 09:06 AM   #231
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Lynn
Yes, when I log back in, the same thing happens.
The problem does not happen every time I log in, probably more than 50%of the time. But, I do not have a problem with any other website, just the Airforums.
Alan
Old 10-10-2013, 10:34 AM   #232
CanoeStream's Avatar
St. Cloud , Minnesota
Alan, do you browse AIR at all times of day & evening? Or do you browse mostly at one particular time? When? [unlikely problem of running into site updates which tend to occur between midnight & dawn]
Using your 'back' link generally will display a page in your cache and not download new info from the site. Does your usage pattern relate more to one than the other of the following:
  • Situation A: Does your problem exist when you have been using AIR continuously? ie, you previously browsed thread XYZ and were doing something else at AIR before returning to thread XYZ and received the 'cannot be displayed' notice.
  • Situation B: Does your problem happen when you have been using AIR and browsing thread XYZ, then you go on and use your computer for other matters and get the 'cannot be displayed' when you return/refresh/back-page?
The AIR server will time out your login if you've been inactive for a period. Backing up to a page with logged-in privileges (ie, ability to reply, etc) would not be allowed. You would need to log in again and refresh the page (not back up). You can test this by opening AIR in a new tab to see if you remain logged in. Anything like that happening?
We can field your question through the page-bottom 'Contact Us' link (the Help Desk) but I prefer to keep the discussion here so we might get comments from others who have seen this.
5 meter Langford Nahanni
Old 10-10-2013, 05:07 PM   #233
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I log in each time I use the forum, then log out at the end of each session. The remember me function does not remember me for some reason.
I use the forum most mornings and most evenings. During those times I might log in a few times. When I can't sleep, I may use it at any time during the night.
I do not think my problem is because of inactivity. Usually I am switching back and forth between messages. Though, occasionally I will search a topic and read a whole series of pages.
I have tried both using the back button and refreshing the page. The only solution I have found is to leave the forum and visit other websites for 5 minutes or so, then come back and log in.
Alan
Old 10-10-2013, 05:33 PM   #234
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
It just happened again, when I clicked on the Edit button.
This is what I see:
Name:	this page can't.png
Is it possible this could be associated with Outlook. This it happens while I use a link in a notification I received by email.
Alan
Old 10-10-2013, 07:59 PM   #235
Ottawa , ON
I would recommend you try a good system cleaner, such as the free one from Piri Software.
Called 'CCleaner' (it used to be called 'Crap Cleaner') you can run a good, risk-free Cleaner for all the various and sundry caches there are, and also, there is also a very solid program that goes through your Registry and will straighten things out there, too.
I have used it regularly for many years, and I find it safe, easy to use, and it has never let me down. For example, after you run the 'Analyze' part of the Cleaner program, you can go to 'Options' and select what cookies you want to keep so as not to have to log on manually to every site.
Without going into more details, and from following your discussion here, I have a hard time imagining your problems have anything to do with Airforums.com. I suggest you try something thorough like CCleaner, and see what you get for it.
www.piri.com/ccleaner or it's available on filehippo.com. Look for the free version, they do a good job of hiding that one, but it is there.
Best of luck!
ps: I have no connections to that company, other than being a very satisfied user.
Old 10-10-2013, 09:05 PM   #236
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Originally Posted by Aage View Post
Without going into more details, and from following your discussion here, I have a hard time imagining your problems have anything to do with Airforums.com. .
Why then do I not have this problem with any other website?
Alan
Old 10-10-2013, 09:57 PM   #237
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Perhaps because you wisely spend more time here than at other sites?
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 10-10-2013, 10:57 PM   #238
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Haha!! There is some truth in this statement.
You been talk'n to my DW?
Alan
New Chat Room Features doorgunner Forum Admin, News and Member Account Info 3 11-15-2006 10:45 AM
Software upgrade information and features... Andy R Our Community 2 04-13-2004 08:33 PM
