Old 09-01-2015, 04:13 PM   #1
2005 22' Safari
Fort Collins , Colorado
Cool Mounting TV?
Just got a 2005 Safari 22' & want to add a TV above the refrigerator. Is it best to attach a wall mount or build a frame up from the refrig cabinet. If wall mount, what is technique, without running bolts through the entire wall?
Bob s is offline   Reply With Quote
Old 09-01-2015, 08:03 PM   #2
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
Swivel mount, bolts through wall, remove tv when in transit.
Swivel mount in the correct location allows for viewing in both directions.
OPINION
kennethowens is offline   Reply With Quote
Old 09-01-2015, 08:17 PM   #3
Morgan guy's Avatar
2007 27' Classic FB
Fredericksburg , Texas
I don't know if your wall situation is different from mine. I was mounting a TV in the bedroom on a swivel and the wall was 1/2" plywood. I mounted the swivel on a sheet of aluminum that was 8" X 10" x1/8" thick. I then screwed the mounting plate onto the plywood wall. I think the TV is about 22 or 23". Have not had a problem with it since I installed it.
The Tex-i-can is Ready to Camp
Morgan guy is offline   Reply With Quote
Old 09-01-2015, 08:33 PM   #4
1975 Argosy 24
Malakoff , Texas
Yes...I also added a plate for a larger footprint to dissipate the pressure points.
Good point of detail :-
Honda Generator Mounting dmac Our Community 24 07-17-2016 10:46 PM
Wheel mounting stud ruined, Where to find replacement? Land Yacht Deb Wheels, Hubs & Bearings 3 09-06-2003 03:25 PM
Solar Panel Mounting JaceBeck 1999 Safari 2 02-26-2003 04:55 PM
LP Tank Mounting bracket kzener40 LP Gas, Piping, Tanks & Regulators 1 08-21-2002 05:40 PM
Antenna Mounting niftypkg Electrical - Systems, Generators, Batteries & Solar 25 08-19-2002 07:03 PM
