Old 07-15-2017, 10:39 AM   #1
1972 31' Sovereign
Carbondale , Illinois
massive water leak
when I hooked up to city water water came pouring out of the belly pan. Is there a valve needs closed, switch thrown or something else that needs done. Trailer has sat unused for 25 tears but was drained and stored properly. Any help will be greatly appreciated.
solo pilot is offline   Reply With Quote
Old 07-15-2017, 10:49 AM   #2
Long Island , New York
Maybe all of the above, plus some possible cracks/breaks where a pipe froze. I would start opening every interior and exterior door and access panel you can find, in order to see the leak in person. You could turn the hose bib on just a little, to see if you can hear the leak or leaks inside a wall or floor.
Do you have the owner's manual? That will help locate things like the water heater (incl. drain plug), pump, pump filter, low point drains, and so forth. If you need a link for an online PDF of your manual please advise and I will find it.
Good luck!
Peter
PS -- Welcome to the forum!
Old 07-15-2017, 11:17 AM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Welcome !!!
One sneaky trick: Hook up an air line to the water input and see if you can *hear* a leak. Yes, you need to be a bit creative about minimizing compressor noise. A long air hose plus a closed garage door usually do the trick ... Do be careful about pressure. Anything over about 60 lb is probably not a good idea when doing this.
Massive leaks and destruction daa1111 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 46 06-30-2017 06:46 PM
Massive Fresh Water Leak 1976 Sovereign LHC007 Plumbing - Systems & Fixtures 8 07-09-2014 04:01 PM
Looking for Local Specialist for massive renovation - S.F. Bay Area NomadKitchen General Repair Forum 8 07-23-2009 07:13 AM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
