08-23-2017, 07:55 PM
2015 27' FB International
stow
, Ohio
Lubricating Main Door Hinges
A/S Question
Hinges are creaking and need to be lubed. Have heard not to use WD-40 as it leaves a film. What is best product to buy and use for this application.
Thanks, Mike
08-23-2017, 08:10 PM
Biloxi
, Mississippi
Silicone spray.
MICHAEL
08-23-2017, 08:13 PM
2009 25' FB International
2018 27' Globetrotter
Tavares
Originally Posted by AWCHIEF
Silicone spray.
Is there anything related to lubrication for which silicone spray should not be used? It seems to be the go to solution on anything needing lubrication.
08-23-2017, 08:55 PM
Oswego
I use dry lube. Mountain bike dry chain lube is my go to wherever I don't want to attract dust and grime.
-Rich-
08-23-2017, 09:02 PM
2016 25' Flying Cloud
Holly Springs
, Mississippi
Try Rem-Oil. It's much better than WD-40 and seems to hold up better (i.e., lasts longer) than silicone sprays.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
08-23-2017, 10:20 PM
1999 34' Excella
Hillsboro
WD to clean only. Gun oil made to handle environmentals. Also, I use LPS 2.. it is an industrial lube, spray and bulk. Also good for MC cables.. after WD clean and flush.
LPS works on weapons too... the 1 is light.. 2 then 3 heavier weights. The 3 stays on longer so fewer dribbles. Just wipe off to keep clean.
There is now Teflon spray but I cannot say how that works on hinges.
Peace and Blessings..
Channing
WBCCI# 30676
08-23-2017, 10:28 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
We use Houdini, a professional lock lubricant.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
08-24-2017, 12:20 PM
2016 30' International
Quartz Hill
I use silicone spray. it doesn't attract dust and grime.
08-24-2017, 12:29 PM
Tampa
Three in One oil?
I always seem to have a can sitting around. Can seals tight.
The problem with a spray is a hinge needs for the lube to find it's way down into the hidden recesses of the pin. I like a very light oil, including a gun oil like Eezox.
08-24-2017, 04:56 PM
2016 26' Flying Cloud
2016 20' Flying Cloud
St Petersburg
Originally Posted by Carrma
A/S Question
Thanks, Mike
I use white lithium grease.
08-24-2017, 05:02 PM
2014 25' Flying Cloud
Cuddebackville
, New York
As said, WD-40 is not a lubricant. Silcone is a short lived one. That being said, it's pretty easy to lube the hinges fairly often.
I use Corrosion-X.
2019 Ford Expedition Platinum
08-24-2017, 07:46 PM
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario
, Ontario
Three in One.
08-24-2017, 08:10 PM
:SPACE A" S/O 11 Air19745
2006 34' Classic S/O
Fort Worth
Don't use silicone around areas you may later want to paint, clear coat, or seal. It will have to be abraded off, unless a lot of time passes for the elements to dissipate it.
guskmg
