Old 06-08-2015, 03:29 PM   #1
1974 25' Tradewind
Ocean Springs , Mississippi
Leak in Belly Pan
I have a 1974 Land Yacht and haven't used it in 3-4 years. I'm trying to sell and when I hooked up the water, it immediately started dripping water out of the small drain holes in the tank shroud or belly pan area. Does anyone know a ballpark figure of what it would take to fix this?
Thanks in advance,
Rhonda
wombo is offline   Reply With Quote
Old 06-08-2015, 03:44 PM   #2
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
It depends on what is leaking. My guess is the repair will be fairly simply once you get to it but removing and repairing the belly pan will likely be the most expensive part.
BambiTex is offline   Reply With Quote
Belly Pan, No Belly Pan DryFly General Repair Forum 33 10-07-2018 08:41 PM
Removing Belly Pan garp Belly Pans & Banana Wraps 5 07-06-2016 01:48 PM
belly pan removal skip Belly Pans & Banana Wraps 6 08-17-2003 07:58 AM
Belly Pan Gaps? ajjohnsons 2003 Safari 6 07-22-2003 08:16 PM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 07:03 PM
