Old 07-27-2005, 03:17 PM   #15
sovereignrwe's Avatar
1972 31' Sovereign
Oakdale , Minnesota
I think I found it. Go to User CP and if you have Karma that has a comment, there will be a blue section (like the time/date bar that separates posts) that reads "Latest Reputation Received" has a "## points" total in that line.
Karma going out for the hint (MarkJoanDoll)!
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is offline   Reply With Quote
Old 07-27-2005, 03:23 PM   #16
1972 31' Sovereign
Oakdale , Minnesota
I owe Janet Karma too! How do I give Karma to someone for a PM?
<--- right back to
Mark
Old 07-27-2005, 03:38 PM   #17
1972 31' Sovereign
Oakdale , Minnesota
<--- right back to
Oh no!!! I can't give Janet Karma. PM Karma doesn't exist. The normal Karma doesn't either. I get a message that I need to spread Karma around. I'll try to capture the message.
Mark
Old 07-27-2005, 03:39 PM   #18
1972 31' Sovereign
Oakdale , Minnesota
vBulletin Message
You must spread some Reputation around before giving it to Janet again.
Mark
Old 07-27-2005, 03:41 PM   #19
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 90
General info about Karma...
Here is how it works.
You earn karma power by:
- 1 point for each year of membership
- 1 point for each 250 posts
- 1 point for every 50 karma points you earn
The amount of karma you earn is based on the karma power the person giving you karma has. So if I have a karma power of 8 and give you good karma then your karma increases by 8 points.
Here are other rules
- you can only give 10 people karma per day
- you have to give 10 different people karma before you can give the same member karma again
- all members have 10 karma points by default
- If a member has less then 5 karma points their "karma hits" do not count towards any other members until they get their karma back above 5.
- a member must post at least once before their "karma hits" count toward other. So if a member has never posted, they can still leave karma but it wont have any effect on the user.
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 07-27-2005, 05:02 PM   #20
1972 31' Sovereign
Oakdale , Minnesota
I'll keep trying. I feel like I'm giving. I'll get there and share it then!
Mark
Old 07-27-2005, 07:27 PM   #21
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
153 and counting...
Looks like I have 153 points. How many do i need before I get a free Airstream?
Old 07-27-2005, 07:46 PM   #22
norbert's Avatar
1993 30' Excella
chicagoland , north of cheddar curtain
Images: 24
or a free gas fire pit......
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 07-27-2005, 08:05 PM   #23
Well Preserved
1993 21' Sovereign
Originally Posted by redeagle313
We are at 44, and I have no idea if that is good or bad.
It is better than having -44. And another dose for you, while I am at it...
Old 07-27-2005, 08:07 PM   #24
Well Preserved
1993 21' Sovereign
Originally Posted by balrgn
Poll might be an idea however, like RichardT it is not something I strive to aquire. Just want to pass on what little knowlage I have in a hope it helps not hinders someone.....
I look at karma points as times I have helped someone, whether it is to help them with their trailer problems, or just helped them laugh for a minute.
Old 07-27-2005, 08:55 PM   #25
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Old Karma
Would you believe that Karma is an old concept.
This very forum used to have a karma system in its early days.
Would you believe that many members here had in excess of 1000 - 2000 points of karma?
I am very confused with the new system of attaining karma, a lot of thinking if you are concerned with it. But I figure why spend time contemplating the issue, the forum will probably absolve Karma again sooner or later.
smily is offline   Reply With Quote
Old 07-28-2005, 11:17 AM   #26
Administrator
Andy R's Avatar
1961 16' Bambi
Dallas , Texas
Images: 13
The reason karma was disolved before was because it was 'hacked' into our old software when we were running version 2.x of the forum software. When we upgraded to v3.x it was a native feature. The native feature uses a different way of calculating karma then the old system. The old system gave you points for starting threads that got lots of page views, karma for every post, etc. The new system is based on explicit recognition by other members for posting quality content. The amount of karma received is based on the karma givers reputation. Their reputation is based on total posts, karma earned and tenure. That way a longer tenured member that has earned a lot of karma and made many posts will give you more karma points then a newbie.
Trust me, I would have brought over the old points if there was any way to make them compatible. There is now a 'hack' out that allows for a system like our old one and I have thought about installing it. It would then be rivet points and they would be earned like before and karma points would also earcn you rivet points. Gets even more confusing, so until we upgrade to v4.x I think we should stay with our current karma system.
The karma system is intended to simply be a nice way to recognize each other for making quality posts. so if you see a post that is 'worthy' then please leave them some karma.
AIR # 2 - 1961 Bambi - Jeep Cherokee
Campground Reviews: Submit and review campgrounds around the US
Andy R is offline   Reply With Quote
Old 07-28-2005, 03:17 PM   #27
1972 31' Sovereign
Oakdale , Minnesota
Hope we can keep the Karma system. Some Karma is far better than no Karma.
Mark
Old 07-28-2005, 08:11 PM   #28
norbert's Avatar
1993 30' Excella
Images: 24
makes sense to me...
Karma?? winner Airstream Motorhome Forums 2 11-19-2002 05:41 PM
Great ways to earn extra Karma... Andy R Our Community 4 07-15-2002 02:19 PM
