Old 02-16-2014, 10:38 AM   #1
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Increasing number of "Latest Discussions" displayed via Portal
By using the Portal, one pulls up the "Latest Discussions" and the list is the last 25 posts in my case.
How does one increase the number from 25 to say the last 50 or 75?? This board is quite active and last 25 just doesn't quite cut it.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2019 Canopenian
Alphonse is offline   Reply With Quote
Old 02-16-2014, 11:01 AM   #2
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
Alan, one workaround to this problem:
-increase number of posts to show per page to 50 or 100 (control panel/edit options/number of posts to show per page)
- then use Quick Links/Todays Posts rather than Latest Discussions
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Old 02-16-2014, 11:08 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I logged in, selected "New Posts" and bookmarked that page. Now every time I select my AirForums bookmark, what comes up is only the threads with unread posts since the last time I looked at the forum. Threads with no new posts since the last time I looked aren't displayed.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-16-2014, 11:33 AM   #4
jcl
Vancouver , British Columbia
Related question: I use "new posts"to catch up. It seems to me though that it doesn't always include all sub forums in the search. If I press it again a few minutes later the list can be different. Do others have similar issues?
jcl is offline   Reply With Quote
Old 02-16-2014, 12:08 PM   #5
TinTin's Avatar
Canmore , Alberta
Yes, New Posts is probably better than Todays Posts, unless you're a multi-visits-per-day user. For either link, it's a good idea to increase the 'number of posts to show per page' to 50 or 100.
JCL, I assume that the list of New Posts will update and change every time you read a thread, or someone else adds a new post. Perhaps this is why threads in 'new' sub-forums appear now and then?
Bob and Nancy
Old 02-16-2014, 12:11 PM   #6
Every time you read a thread and then come back to New Posts, it updates.
If you open "New Posts" and let it sit without reading anything, it won't update until you refresh the screen.
WBCCI #1105
TAC LA-4
Old 02-16-2014, 12:15 PM   #7
jcl
The problem is that some sub forums don't appear to be included in the search. An example would be the three tow vehicle and hitch sub forums. That is where I usually notice threads missing from the new post search. I go to those three sub forums after browsing new posts and read all the bold ones that didn't appear in the new post search.
Jeff
Old 02-16-2014, 12:22 PM   #8
jcl
That is the problem. This thread, and your responses, don't show up when I click the new posts button. Does it exclude threads I have a post in? I see a line that says the most recent search was generated three minutes ago, so there is a periodic refresh, it isn't on demand so to speak.
Using an iPad, browsing in Safari.
Jeff
Old 02-16-2014, 12:39 PM   #9
Ottawa , ON
IIRC, the 'New Posts' selection only removes posts that you have read.
AC Model Number Al and Missy Furnaces, Heaters, Fireplaces & Air Conditioning 1 01-26-2014 08:42 PM
AIR Number Frankiefiveo Title, VIN & Registration 1 02-07-2012 11:25 AM
LED house number sign invention emergency johnobuttons Off Topic Forum 6 09-11-2011 11:43 AM
Portal?? kdenault Forum Admin, News and Member Account Info 4 08-01-2011 02:20 PM
Part number needed sharptalk Mechanics Corner - Engines, Transmission & More... 5 06-02-2011 01:11 PM
