Old 12-13-2018, 02:51 PM   #1
92landyacht's Avatar
1992 36' Land Yacht
Grayson , Georgia
How to combine accounts?
A number of years ago I was an active member under the user name jt92LandYacht. I took a couple year sabbatical from the forum. When I rejoined I found that I could no longer log in under my original user name. I was forced to create a new user name jt240z. Anyone know if there is any way I can combine both accounts under the original name? I had a lot of history under that name and would like to maintain that history.
92landyacht is offline   Reply With Quote
Old 12-13-2018, 04:24 PM   #2
Kevin245's Avatar
You'll need to contact the HelpDesk using the "Contact Us" tab located on the blue command bar located at the bottom of this page. They will contact you and work this out.
Regards,
Kevin
Eleanor Roosevelt
Old 12-14-2018, 07:09 AM   #3
1992 36' Land Yacht
Grayson , Georgia
Thanks. Just did it.
Old 12-15-2018, 01:49 PM   #4
1992 36' Land Yacht
Grayson , Georgia
I never go a response back but was able to log into my original account. Silly me... I was using the wrong name. It wasn't JT92landyacht. It was simply 92landyacht.
Now if I could only get the two accounts merged.
Combine AC and DC Breaker/Fuse Panel ASNomads Batteries, Univolts, Converters & Inverters 7 04-07-2014 09:05 PM
Help an HVAC noobie out... can I combine the furnace and A/C t-stat? Taylormade Furnaces, Heaters, Fireplaces & Air Conditioning 10 05-16-2012 03:13 PM
What Do You Get When You Combine... GlenCoombe Classic Motorhomes 7 01-26-2010 09:18 PM
Combine Members rslaymaker Forum Admin, News and Member Account Info 1 08-21-2008 09:32 AM
Can I combine my personalities? froggies Forum Admin, News and Member Account Info 7 08-09-2006 11:09 PM
