Go Back   Airstream Forums > Airstream Community Forums > Forum How-To's & Support
Old 11-18-2007, 03:12 PM   #1
Janet
Janet's Avatar
Profile:  Eastern , Washington
Images: 63
How to search the forum
There are a couple of ways to search the forum. If you have a question we recommend that you search before posting. There's a fair chance that we have a several posts about your topic of interest.
The Forums search tool found on the upper blue nav bar is fairly easy to use and really quick. Our search tool searches for key words and you have a choice to search for threads or posts. Consider using the advanced search function to narrow down your choices. You must be logged into the forums to use the search tool.
Search using Google's search tool for a more accurate result.
You can search only this forum using google. To do this, open a google search window in your browser and key in your seach parameters, leave a space and then type site:www.airforums.com.
Example: If you want to find info about red bearing grease your search would look like this:
red grease site:www.airforums.com Don't forget to hit enter.
Name:	search forum.jpg
77 Argosy Minuet, 6 metre
77 Argosy 24, Rear door
AIR 3181, WBCCI/VAC # 5575
Wally for President
Janet is offline   Reply With Quote
Old 11-18-2007, 03:32 PM   #2
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
Janet,
While I do not expect you to know the answer to my question, perhaps you could pose it in the Moderator's Forum where Andy R might see it:
Why does vBulletin have such a poor search engine?
I think it is because the creators want people to ask the same old questions. Asking questions generates traffic. Traffic generates revenue when Google ads are involved.
Tom
Old 11-18-2007, 10:57 PM   #3
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
Originally Posted by TomW
Janet,
Tom
But not searching first sure puts a bee in the bonnet of a few folks...
Fyrzowt is offline   Reply With Quote
Old 11-18-2007, 11:07 PM   #4
Andy R
Administrator
Andy R's Avatar
Profile:  1961 16' Bambi
Dallas , Texas
Images: 13
Tom, lots of people complain about the search feature of vBulletin. Hopefully they will come out with a better system in their future releases. I plan to integrate a Google search into the site soon. Then we will need to make the search box easier to find to try encourage people to use it.
AIR # 2 - 1961 Bambi - Jeep Cherokee
Campground Reviews: Submit and review campgrounds around the US
Andy R is offline   Reply With Quote
Old 11-19-2007, 10:21 AM   #5
Zeppelinium
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
Janet, thanks. Your technique works great!
Zep
Current 6-word memoir: Vintage Airstreams: Four are not enough.
www.mindseyephoto.com www.airstreamdoctor.com
Old 12-10-2007, 06:20 PM   #6
fotochop
fotochop's Avatar
Profile:  1969 23' Safari
New Orleans , Louisiana
may be a dumb question
Should I use "+" or "&" signs between words to do a multiple-word-specific search? For example, I want to search for "wheel well" but not have every post/thread come up with the word "wheel" in it, only "wheel well". Would I use "wheel+well" or something like that?
Couldn't find an answer to this searching.
thanks,
fotochop
fotochop is offline   Reply With Quote
Old 12-10-2007, 06:56 PM   #7
Janet
Janet's Avatar
Images: 63
fotochop
If you want to search AIR for "wheel well" your google search would look like this:
"wheel well" site:www.airforums.com
You could also use the google advanced search page
which will allow the kind of search you want and you can specify that it only searches this site.
Google has some nifty tips for searching using the advanced page and even more info on the basics of searching here
Finally - check out the google cheat sheet.
Print this and stick it to the corner of your monitor.
The vbulletin advanced search only searches key words and gets somewhat befuddled when you add punctuation.
Wally for President
Old 12-10-2007, 07:15 PM   #8
2airishuman
2airishuman's Avatar
Profile:
I want to search for "wheel well" but not have every post/thread come up with the word "wheel" in it, only "wheel well"...
without going to the 'google' approach, here is another suggestion...
find a specific subform, like running gear or frames or floors or something under exterior restoration, or even a specific model/year...
or limit the search to a well known USER restoration thread like the ones from uwe or norcal bambi,
or an 'expert like inlandandy...
then go to advanced search....
in advanced search enter 'wheel' only or 'wheel well'.
well only won't search easily because it's too common and short of a word like 'if'...
limit the search to ONLY one or 2 of your preselected subforums or members...
http://www.airforums.com/forums/sear...earchid=902894
you can also limit the search to theads with only wheel well in the TITLE
and don't forget the common mis usages, like wheelwell....
and bam!!!!!
http://www.airforums.com/forums/f4/c...ells-3504.html
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 12-10-2007, 07:34 PM   #9
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Like 2air sez. Advanced Search. Really helps to remember somebody who posted in a thread. Switch "Sort results by" to 'Relevancy.' Try it alternately with 'Show Results as' posts and then threads. That helps sort through threads with a lot of responses.
Earlier this evening I tried to search for the member who had a photo thread about transporting his vintage Airstream to Vancouver Island on a small barge or ferry. I failed miserably...
Old 06-30-2008, 08:04 AM   #10
missysanford
newgirl
Profile:  1993 29' Excella
springfield , Missouri
I can't get the search to work. I type in a name and it doesn't do anything. What's up?
missysanford is offline   Reply With Quote
Our Search Is Over tincan4us Member Introductions 7 05-10-2006 06:59 PM
Search - Where did SEARCH Go? Foiled Again Forum How-To's & Support 4 10-16-2005 09:49 PM
Search is Over jalewis Airstream Trailer Forums 5 09-10-2003 08:05 PM
In Search of... JeffH Parts Archive 6 09-08-2003 10:49 AM
Airstream Forum Blues-suggestions for forum usage hex Our Community 18 10-20-2002 11:12 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
