Go Back   Airstream Forums > Airstream Community Forums > Forum How-To's & Support
Old 07-14-2002, 09:40 PM   #1
Jim Clark
Jim Clark's Avatar
Profile:  2005 25' Safari
New Orleans , Louisiana
How To Animate Your Avatar
How to make your Avatar switch pictures. The inspiration for this came from the floating rivet avatar. I liked it a lot and thought it was cool so I deconstructed it to see how it was done . I then realized that the board would let you do animated GIF’s. My tool of choice is GIF Construction Set Professional. You can get a evaluation copy version from Alchemy Mindworks. http://www.mindworkshop.com/alchemy/alchemy.html
1.You will need to down size your pictures to apx. 105 X 70 pixels 256 colors. I use Photo Shop 6.0 to do this. Save as GIF.
2.Crank up GIF Construction Pro and use the Animation Wizard for your first one. After you are complete upload as a custom Avatar to the forum. This program has a lot of features so you can do a lot. The board has a file size limit on the Avatar file so you may run up against that wall.
3.Let everyone know the tricks you come up with, have fun.
First Weekend Shindig @ Topsail First Weekend in Jan.
Thanks Jim, N5TJZ
2005 25' Safari ,AIR# 174
S/V Wandering Spirit
http://airstreamlife.ning.com/profile*/JimClark
Picture Gallery
http://gallery.mac.com/jimclark6#gallery
Jim Clark is offline   Reply With Quote
Old 07-14-2002, 11:32 PM   #2
Andy R
Administrator
Andy R's Avatar
Profile:  1961 16' Bambi
Dallas , Texas
Images: 13
You can also use online tools!
I intentionally set the thumbnail size @ www.airstreamphotos.com to be compatible with the avatar. The following instructions are only valid if the photos you are uploading are .gif files! If they are .jpg or .jpeg, you will need to wait until someone can post an online conversion tool before you can follow this process.
Follow these steps:
1. Upload the images you want to use.
2. Next go to your gallery by either using the link from your Member Control Panel or from the "Photo" button below any post you have made.
3. Right click on the thumbnails you want to use and save them in a folder on your computer. Remember which folder you saved them in so you can upload them in the next step.
4. Go to GifWorks.com and use "Method 2". Upload the first thumbanil you want to display.
5. Follow the directions to create an animated gif then save the new animated image to your hardrive.
6. From your Edit Options select "Change Avatar and upload your new animated .gif.
That's it!!!
Somethings to think about. Each image/rotation you add increases the final animated image file size. The larger everyone's Avatar is the slower the page will load. Try and keep your Avatars to less than 5 images or frames for sure! Less if possible...
Please post your feedback on this thread. If you all find any other online tools that are good, post them here also!
AIR # 2 - 1961 Bambi - Jeep Cherokee
Campground Reviews: Submit and review campgrounds around the US
Andy R is offline   Reply With Quote
Old 08-23-2002, 12:44 PM   #3
Scotti
Scotti's Avatar
Profile:
Images: 8
Angry removing photso how to?
it sz I dont have oermission whats the deal?
Scotti D.
Scotti is offline   Reply With Quote
Old 08-23-2002, 05:09 PM   #4
mkeith54
mkeith54's Avatar
Profile:  1976 26' Argosy 26
New Florence , Missouri
Thumbs up File Converter/Viewer
For those who need a free file conveter and viewer click here http://www.ryansimmons.com/users/irfanview/ this is a freeware program that does it all and does it well.
mike
Mike Keith
75 Argosy 26'
96 Ford F-250 PowerStroke
WBCCI 4503
Gr8r STL Unit
mkeith54 is offline   Reply With Quote
Old 08-24-2002, 04:46 PM   #5
Jim Clark
Jim Clark's Avatar
I just tried Andy's method for a animated .gif. It seems to be exactly what he states, it will animate one thumbnail, which must converted to aGIF before upload. If you want to flip between thumbnails you will have to use the method in the first post. I did not spend a lot of time at Gifworks so it may contain a way which I haven't discovered yet.
Here is what you can do.
Create your own special effects with any GIF -- even animated ones! Resize it, colorize it, optimize it, and jazzercise it -- then save it and take it with you. You name it and you can do it! If you have any feature suggestions let us know.
Thanks Jim, N5TJZ
Picture Gallery
Old 08-25-2002, 02:31 AM   #6
Rog0525
5 rivets, 1 loose screw
Rog0525's Avatar
Profile:  1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Free animator
A very simple animator can be downloaded from this site (it is freeware and the file size is only 19.5 KB).
http://www.whitsoftdev.com/unfreez/[/url]
You simply drag and drop your gif images to the screen, select the frame delay, then click the "Make Animated GIF" button
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Rog0525 is offline   Reply With Quote
Old 08-25-2002, 05:36 AM   #7
Jim Clark
Jim Clark's Avatar
Re: Free animator
This sounds geat, thanks.UnFREEz 2.1
UnFREEz is a high-speed Windows application that will take any number of images, saved as separate GIF files, and create a single animated GIF from those images. What makes this program unique from its competitors? First and foremost, UnFREEz is freeware, which means you may use it forever without paying a cent or feeling the slightest bit guilty. Secondly, UnFREEz is incredibly tiny, meaning you don't have to spend forever downloading an extremely bloated piece of software. Finally, it is so easy to use. Just drag and drop some GIF files from Explorer, set the frame delay time, and hit Make Animated GIF. UnFREEz will take care of the rest, including automatic interlacing and transparency detection. So download UnFREEz now and try it out for yourself! If you like it, keep it; it's free! This program is written in non-MFC Win32 C++, and should not need any additional files to run.
Thanks Jim, N5TJZ
Picture Gallery
My new avatar donnall Airstream Motorhome Forums 6 12-14-2003 04:49 PM
Changing My Member Picture (Avatar) cljackson Airstream Motorhome Forums 1 02-23-2003 08:04 PM
Custom Avatar mwilleford Our Community 2 03-22-2002 11:02 PM
How to use your own Avatar... PeterH-79MH Forum How-To's & Support 2 02-23-2002 07:19 PM
