Old 08-13-2017, 06:54 AM   #1
1972 29' Ambassador
Knoxville , Tennessee
Hauling airstream without subfloor
I have someone who is going to weld frame damage on my 72 ambassador. Problem is he is located 1.5 hrs away from where I am working on the airstream. I am wondering if it is possible to haul the airstream to him with the subfloor removed or would the shell come off the frame in transit?
Silverback01 is offline   Reply With Quote
Old 08-13-2017, 08:34 AM   #2
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
I'm surprised no one has answered. I think you're asking for trouble. The subfloor acts as a shear element, stiffening the lower portion of the trailer. Without it, as you move down the road the frame will be torqued and twisted by going over bumps, hitting dips, swaying from side to side and being buffeted by winds. I think at the very least you'll end up twisting some frame members, probably worse. If you must do this try attaching some temporary plywood to the frame, take the back roads and drive very slowly. Let us know your route and date of travel so we can be sure to be out of state that day
DryFly is offline   Reply With Quote
Old 08-13-2017, 08:47 AM   #3
1977 31' Sovereign
Sunset Valley , Texas
While not the ideal condition to transport your trailer, it's not impossible and has been done many times. Someone is probably doing it right now.
I'm not certain how much "shear" strength really matters as much as the shell being connected to to the frame. Since the shell/subfloor/frame combine into one unit, your trailer may only be attached by the lower belt line. Is the interior skin in?
With some judicious placement of some 1x4 cross bracing and as the above poster said, going slow, you should be fine. As long as the shell is attached to the frame.
Your 1.5 hour drive may end up being 3hours, but hey, you gotta get the thing fixed right?
Iansk is offline   Reply With Quote
Old 08-13-2017, 09:04 AM   #4
Central , Mississippi
The risk is that the shell will spread open and fall off the outriggers, the shell kinda swallowing the frame and falling to the road. I suggest adding some lumber along the sides screwing to the ribs and the outriggers
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-13-2017, 09:28 AM   #5
Half a Rivet Short
Carlisle , Pennsylvania
Hi
... errr ... welding damage on the frame?
I would be at least as concerned about the frame as anything else. The floor and the frame to some degree work together to add strength. A lot depends on exactly what your frame issues are.
Old 08-13-2017, 10:36 AM   #6
1972 25' Tradewind
Calgary , Alberta
If you have no sub floor how is it attached to the frame?
Why not just lift the shell off the frame and transport the frame only, easiest for the welder as well.
Monza is offline   Reply With Quote
Old 08-13-2017, 11:42 AM   #7
1971 31' Sovereign
1972 31' Sovereign
1967 22' Safari
Soddy Daisy , Tennessee
I pulled my 1972 31' Sovereign from Newport Tn to Soddy Daisy Tn with 2" straps holding my shell on after we threw the pieces of plywood on the frame and piled all of the loose interior parts on the plywood. My 31' is almost finished now and had not one single problem pulling it that distance and it mounted perfectly. I slid some small pieces between the frame and the channel to help support a little bit.
cole3444 is offline   Reply With Quote
Old 08-13-2017, 12:02 PM   #8
Long Island , New York
Echoing the questions raised so far, and also the need for towing to the welder.
Wouldn't it be simpler to have a welder come to the trailer?
For all the effort you have to make to get to him, plus the risks of problems, the cost of hiring a welder seems like a relatively lower cost IMO.
Good luck!
Peter
Old 08-14-2017, 07:25 AM   #9
1 Million Rivets
1978 Argosy 27
1976 Argosy 26
Elk Rapids , Michigan
Most pro welders have mobile trucks. Find someone who will come to you or do it yourself.
matthewsx is offline   Reply With Quote
Old 08-14-2017, 03:53 PM   #10
1972 29' Ambassador
Thanks for the responses everyone. Think I'm just going to remove the shell and just transport the frame.
He is mobile. Problem is work in shop is only $35 an hour. If he has to travel it's upward of $60. Plus, he does any needed fabrication in his shop, so it's better to have the airstream on sight.
Remove Subfloor Without Stripping Aesbestos Floor Tiles? Knoxvegas Repairing/Replacing Floor &/or Frame 27 09-19-2012 12:31 PM
Replace Subfloor without removing shell? Phrunes Repairing/Replacing Floor &/or Frame 8 05-07-2012 11:11 AM
Vinyl tile subfloor preparation without replacement star kitty Repairing/Replacing Floor &/or Frame 7 11-07-2010 07:52 PM
Options for hauling bicycles?? 2003 International CS rmmm68 2002 - 2005 International 4 02-07-2003 07:54 PM
