Old 10-15-2015, 03:43 PM   #1
Murrells Inlet , South Carolina
Generator
What generator do I need to buy to run my air stream 25 .
hfieldsyoung is offline   Reply With Quote
Old 10-15-2015, 03:51 PM   #2
1986 31' Sovereign
Miami , Florida
If you want to run the A/C, then the most common setup is a Honda EU2000i run in parallel with a Honda EU2000 Companion. Both are lightweight and sip gas.
There are 3000 watt generators that will run most everything but they are heavier.
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 10-15-2015, 04:15 PM   #3
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
Mike is correct. Their is also Yamaha brand that can be run in parallel, can't go wrong with either choice. Don't make the mistake I did a few years back, buying a cheaper 3000W because it was less expensive, be smart & buy the best.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 10-15-2015, 05:43 PM   #4
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Generator
I run a single Yamaha EF2400 ishc, it works for me. 70 pounds, easy to handle, quiet, compact, and fuel efficient.Click image for larger version
Name:	ImageUploadedByAirstream Forums1444952597.321518.jpg
Since I am a miser, kinda anyway, the price for one Yamaha seemed more in line with my expectations than the price of two Hondas.
Brevi tempore!
Old 10-15-2015, 05:54 PM   #5
Holly Springs , Mississippi
The paired Honda's, or Yamaha's, are a good plan. Each unit weighs about 50 lbs. -- their combined weight is less than one 4000 watt unit. Also, if one of them won't start or otherwise fails, you've still got 2000 watts that'll run the TV's and about everything else but the AC and maybe the microwave.
However, take a look at the 3000 watt Yamaha. It has the ability to put out more than 3K watts on a short-term basis to start the AC. ...but it's heavy.
Take a look at genset.com for more advice.
2016 FC 25' FB twin
2013 F-150 Lariat CrewCab 3.5 EB 4X4 3.55 axle
Bob662 is offline   Reply With Quote
Old 10-15-2015, 06:13 PM   #6
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
But if all you want to do is charge the batteries then a 1000 watt Honda or Yamaha will be all you need. As strictly a battery charger, the 1000 watt units are just as fast as a 2000 watt unit since the batteries can only take a charge at a certain rate which is way below what a 2000 watt generator can put out. The 1000 watt generators are quieter, lighter and less expensive than the 2000 watt models.
Bob Martel
WBCCI# 5766
Parallel non inverter generator with inverter generator? mtbguy Generators & Solar Power 3 07-15-2015 01:48 PM
Solar or generator or and generator? badkat Full-Timing 15 11-17-2014 09:59 PM
Generator Problems thenewkid64 General Motorhome Topics 27 05-07-2003 09:36 PM
Generator Paul Daugherty Airstream Motorhome Forums 19 08-09-2002 08:47 AM
1998-1999-2000 Excella Generator fphil Airstream Motorhome Forums 0 07-01-2002 09:34 PM
