Old 07-05-2013, 07:12 AM   #1
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Forum-message prob
Howdy!
Using the iPhone app I cannot access "private" messages today.... Help, please?
Thanks!
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-05-2013, 07:33 AM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Huh.. well, it works from a PC.. but not from the iPhone...
Channing
WBCCI# 30676
Old 07-05-2013, 09:30 AM   #3
eubank's Avatar
1967 30' Sovereign
Bosque Farms , New Mexico
Channing, this sounds much like a software problem rather than a simple moderation problem. If you could use the "Contact Us" link at the bottom of the page and explain what is happening, you'll be able to get into more direct contact with the site administration folks.
Lynn
WBCCI 21043
Old 07-05-2013, 09:32 AM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Sweet! Thanks yall
Channing
WBCCI# 30676
Old 07-05-2013, 09:34 AM   #5
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I'm using an iPad and it's using version 1.62. I touched the messages envelop that is at the bottom of the screen. My screen changed and shows my private messages.
You might consider shutting down the application completely and then restarting it. Apps sometimes get screwed up and unless you shut them down completely, they sometime will continue to fail.
To completely shut down an application touch the center home button of you iPhone quickly. You should see a list at the bottom of all the applications that are running or in a suspended state. Scroll to find the airforums app and hold your finger on that app (at the bottom of the screen). You will then see a red x on the apps at the screen bottom. Touch the x and the app will be shut down. While you're at it you can clean up all the running apps or just hit the home button again and your regular screen will be refreshed. Run the airforums app again and see if the problem is resolved.
Jack
Jack Canavera
STL Mo.
AIR #56
