Old 05-11-2010, 05:57 AM   #1
gloran's Avatar
1993 33' Land Yacht
Midland , Michigan
Editing a post
How is a post corrected after submission? I have a typo, but see no provision to be able to edit it. Thank you.
gloran - 1993 LY MH 33' - Banks System, Steer Safe, IPD front stabilizer, Super Steer - Bell Cranks, Motion Control, Coil
http://s1290.photobucket.com/user/gl...58808196506793
gloran is offline   Reply With Quote
Old 05-11-2010, 06:00 AM   #2
Kevin245's Avatar
You can edit your posts within the first 30 minutes or so of posting. There should be an "Edit" button in the lower right side of your post.
Kevin
Eleanor Roosevelt
Old 05-11-2010, 06:02 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
An edit button is available for a short period after you make a post. The option to edit will expire and the edit button will then be gone. You can always contact any moderator to make an edit.
Richard
azflycaster is online now   Reply With Quote
Old 05-11-2010, 01:24 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
If you miss making a correction within the time limit for edits, you can ask a moderator fix it, but most typos won't matter unless it a meaning-changing mistake... Most folks are able to "read through" a mistake or typo and can usually figure out what you really mean.
TB & Greg and Abbey Schnauzer
#3954
Old 05-12-2010, 07:34 AM   #5
Ottawa , ON
If we all asked the moderators to correct every typo we made, I suspect they would be a lot busier than they might care to be.
Thankfully, as TBRich pointed out, we speak Monitor here, so unless "on" should be "off" just relax and let it go...
Old 05-12-2010, 07:43 AM   #6
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
The staff at Airforums is here to help any member that needs it no matter how small the issue.
Fixing typos would not be a high priority though.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 05-12-2010, 07:47 AM   #7
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I never make tipos, so I don't need an edit buttin.
Old 05-12-2010, 07:48 AM   #8
Ottawa , ON
Adng a speel-chucker might be more priodocktuv, Lee... Bot ets bn sed that yumns kin red evn th most choodup txt imagnebl.
Old 05-12-2010, 07:58 AM   #9
1967 22' Safari
1960 Caravel
Images: 8
"Dang a sleep-sucker might be more periodontics, Lee... Bot etch bin send that yummy kin red even th most chooser text imaginable."
Spell check Does help somewhat...
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 05-12-2010, 08:28 AM   #10
1977 Argosy 24
Milltown , Wisconsin
Yer not from aroud here are you?
ventport is offline   Reply With Quote
Old 05-12-2010, 09:01 AM   #11
Ottawa , ON
Is that yer Sovereign, or are you just happy to see me?
Editing DVD Turtle Off Topic Forum 12 10-11-2005 12:53 PM
