Old 04-09-2006, 09:21 AM   #1
CasaDelGatos's Avatar
Silverhill , Alabama
"Distance by zipcode" feature broken?
I am absolutely having a ball browsing the forums and learning more about the trailer I hope to own soon. My wife and I need a smallish (less than 24 ft.) TT to pull behind a Kia Sorento (3500 lb towing) so that we can take our cats and valuables and outrun the next killer hurricane.
To that end I check the classifieds every day looking for something in my price range that's not too far away to check out in person. Unfortunately, although I put in my (South Alabama) zip code correctly, the ads tell me a trailer is only 271 miles away (a reasonable distance to go to see it) from me when the seller is in Minnesota. That is actually 1400 miles! Unfortunately, that is not a reasonable distance.
Also unfortunately, there are not a lot of used airstreams in and around the Gulf Coast for sale.
Is there a reason my zip code 36576 is generating these wrong answers?
Thanks!
CasaDelGatos is offline   Reply With Quote
Old 04-09-2006, 09:55 AM   #2
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
Is that a new zip code? We had troubles like that (and other problems) when we were assigned a new zip code.
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 04-09-2006, 09:57 AM   #3
AirstreamGypsy's Avatar
1961 16' Bambi
Mancos , Colorado
Send a message via Skype™ to AirstreamGypsy
zipcode
Casa'
Sorry I can't help ou with the zip code problem but,
Welcome to the forums! Hope you're able to find YOUR airsteam soon. One recommendation, you'll need a larger tow vehicle to tow anything but the smallest trailer. There are many threads regarding towing here on the site. Take a look and consider well before trying to tow with too small a vehicle.
AirstreamGypsy
___________
Charter Member FCU WBCCI 1818 CP(Courtesy Parking) Wi-Fi
My Earthship
AirstreamGypsy is offline   Reply With Quote
Old 04-10-2006, 05:55 AM   #4
Nope, as far as I know this has been the area code for Silverhill for at least 10 years that I know of. I'm thinking whatever database is used for the calculations thinks 36576 is somewhere other than where it is.
Gypsy, thanks for the welcome. As to size, from what I have seen in the ads and of trailers up close, I ought to be able to pull up to about a 22-footer of some kind. I really would like one with tandem axles for the obvious safety benefit.
Casa Del Gatos
Old 04-10-2006, 06:41 AM   #5
Steve & Susan's Avatar
2005 28' International CCD
Willoughby , Ohio
What is the Zip you are comparing yours to?
Part of my business is calculating distances between zip codes.
I show 36576 as Silverhill, AL - correct?
If you give me the other one, I can tell you how many miles I calaulate.
Steve & Susan
WBCCI# 03876
AIR# 6511
2005 28' CCD, 2011 Sierra 5.3L, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 04-10-2006, 06:41 AM   #6
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Casa, I've posted your concerns for the Admins on the Moderators' Forum. I don't have any idea myself of how that feature operates, so perhaps one of the Admins who do (or Andy) can look into it.
I echo AirstrmGypsy's concerns about your tow vehicle. The only current Airstream you might be able to tow with it would be the 16' Bambi with a GVWR of 3500 lbs. Everything else is way out of your towing range. And the 16' Bambi, unladen, would be at your max safety range if you are of the belief that allowing a 20% margin under your max tow rating is a good thing.
You could do some of the vintage trailers though; a '50s Flying Cloud, an original '61-'63 Bambi, a '64 Bambi II, or the '65-'68 Caravels would all work for you if you pack lightly...
Roger
Old 04-10-2006, 07:53 AM   #7
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Casa Del Gatos
Good luck! If you are talking an Airstream made in the last 5 years (or a bit older), you are at the 16' Airstream size and even that is too big for your TV (tow vehicle). If you go vintage, you **might** be able to find something, but even then, perhaps not bigger than 19' if that. Problem is that people, fuel, cargo all get deducted from the total tow rating of the TV. For example, if you and your wife weight 100lbs each and you carry 100lbs of stuff in the car and you fill the fuel tank (say 10 gallons @6lbs per gallon) you have now lowered the towing capacity from 3500 to 3140 and for each pound that I'm off, deduct further. I agree with what has been said, unless you go with a pop up, or some other camper in the 2000lb range, you are looking at a better tow vehicle before you should ever consider an Airstrem or any other coach weighing 2500 lbs (max) or more.
Old 04-10-2006, 02:27 PM   #8
cameront120's Avatar
1972 25' Tradewind
Is there any way to get this feature to work to include Canadian Postal Codes? The only way the feature works for us is to enter the nearest American city (which could be hundreds of kilometers for some members who live a fair ways to the North).
Cheers!
North Vancouver, BC
Old 04-10-2006, 02:33 PM   #9
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The distance by zipcode feature has been "broken" ever since I have been a member. Up until now, it has been nothing more than a sometimes hilarious inconvenience, but it should be addressed next time we have a forum upgrade. I hope.
https://www.gofundme.com/marie039s-o2-amp-dialysis-fund
Old 05-05-2006, 05:37 AM   #10
Cape coral, , Florida
I am new to the forum too, but someone selling an item perhaps should put their city/state in their description just as a aid to those searching. I have been looking for an Airstream and have been dissapppointed when 28 miles turned into 1800 miles...
KMLAWS is offline   Reply With Quote
Old 05-05-2006, 07:59 AM   #11
Huh?
Ultradog's Avatar
1975 27' Overlander
Twin Cities , Minnesota
Images: 8
Can't help you with the zip codes but...
... I live in MN - Twin Cities area.
If it wasn't too far away I could go look at it for you. I've got a digital camera and could send photos.
No I wont steal it away from you. Got one AS and that's enough.
Jerry
612 968 5248
Ultradog is offline   Reply With Quote
Old 09-21-2006, 11:36 AM   #12
2007 25' International CCD
Arlington , Virginia
If folks did what KMLAWS suggests, you could take that location info stick it into Mapquest and get an accurate distance and directions in no time. All it would amount to is keeping an additional browser window open while you are looking for your AS.
Streamer1 is offline   Reply With Quote
Old 09-21-2006, 12:47 PM   #13
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
The zip code feature on this site is definitely broke. Other sites that use the same classifieds software seem to work.
wacnstac is offline   Reply With Quote
Old 09-21-2006, 12:51 PM   #14
A 7th year newby
IndyAnne's Avatar
1968 24' Tradewind
Indianapolis , Indiana
Images: 8
Send a message via Yahoo to IndyAnne
Zip fubar
Yes, the zip does not work for me, either. That would be a neat feature for browsing Airstreams and parts, campgrounds, etc.
Thanks for sending this to the moderators and administrators.
Anne
Indianapolis, IN
TAC IN-7
1968 Airstream Trade Wind
2005 Chevy K1500 crew, reg. bed, 4WD, gas
IndyAnne is offline   Reply With Quote
New forum feature? airstreamcaravel Our Community 1 11-02-2002 11:22 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 10:09 PM
Broken Window Installation Charcigar Windows & Screens 2 07-30-2002 05:22 PM
Oven gas line broken lbrodsky LP Gas, Piping, Tanks & Regulators 4 07-23-2002 04:52 AM
