Go Back   Airstream Forums > Airstream Community Forums > Forum Admin, News and Member Account Info
Old 02-26-2011, 09:47 AM   #1
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
Confused about Quoting
When I tried to quote a portion of a post today, then submitted my reply, the quote did not show up in a shaded box, looking like a quote. It appeared as though the quote was something I had written. Any suggestions?
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 02-26-2011, 09:54 AM   #2
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
I know there is another way, but I copy/paste the portion that I want to quote into the reply box. I then highlight the quote, then click on the little yellow box on the right above. As you scroll over the icon, it will say "wrap (quote) tags around selected text". Click on the icon, it puts the highlighted text in quotes for you.
Edit: the icon is in the bar directly over the reply area.
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 02-26-2011, 09:54 AM   #3
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Did you include the entire quote or/and the bracketed [QUOTE] as I did here?
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 02-26-2011, 10:08 AM   #4
InsideOut's Avatar
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen , Colorado
Images: 108
The easiest way to quote a post is to click the "quote" button at the post you want to quote. Then when it pops up, edit the text between the html brackets enclosing the [--quote--] edit what's here [--/quote--] (--minus signs added by me so it won't "work" here). That's it...you have to have the brackets...that's what prompts the html. If you don't want to or need to reference the original thread or author, just put the word quote in brackets [word "quote"] and not the other stuff at the beginning. Regardless, you have to end the quote with bracket-dash-quote-bracket [/word "quote"]
If you want to split the quote into multiples, put the portion at the beginning including the brackets "quote..."and add the "/quote" including brackets at the end of each section. Basically, what you are coding is html for "start quote" and "end quote".
When you hit the quote button...look to see what's there are the beginning & end of the quote before you edit it to see what it should look like.
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 02-26-2011, 10:11 AM   #5
webspinner's Avatar
Menlo Park , California
I find it easiest most of the time to use the "quote" button in the bottom of the post I'm trying to quote from.
Then I delete the extraneous parts, making sure to keep the [QWOTE] [/QWOTE] tags at the beginning and end. These tell the computer to put the text in a quote box. (Yes, the misspelling is intentional, otherwise it reads it as real tags and won't show them.)
Barbie
Our travel and renovation blog: https://tinpickle.blogspot.com/
webspinner is offline   Reply With Quote
Old 02-26-2011, 10:11 AM   #6
[QUOTE=FreshAir;956672]Did you include the entre quote or/and the bracketed
as I did here?
Neil
I think I might have deleted the bracketed words "QUOTE" at the beginning and end. Let's see how this looks. My only change to your entry was to delete the "i" in entire.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Old 02-26-2011, 10:20 AM   #7
Then I delete the extraneous parts, making sure to keep the [QWOTE] [/QWOTE] tags at the beginning and end. These tell the computer to put the text in a quote box. (Yes, the mispelling is intentional, otherwise it reads it as real tags and won't show them.)
I'll keep trying, thanks for the help.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Old 02-26-2011, 12:18 PM   #8
InsideOut's Avatar
1956 22' Safari
Images: 108
Not quite...You have the beginning right...but left off the end quote [--/quote--] (minus the --'s)at the end.
Shari
Old 02-26-2011, 12:39 PM   #9
Originally Posted by InsideOut View Post
Not quite...You have the beginning right..but left off the end quote [--/quote--] (minus the --'s)at the end.
Shari
This should be better, thanks.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Old 02-26-2011, 02:01 PM   #10
InsideOut's Avatar
1956 22' Safari
Images: 108
Looks like you got it!
Shari
Brokenhearted and confused..is there a hitch system that will give me some distance KyMoonshine Hitches, Couplers & Balls 24 04-26-2011 10:12 AM
Help. Confused about electrical robwok 1960 - 1964 Overlander 5 02-23-2011 08:30 PM
Confused about albums webspinner Forum Admin, News and Member Account Info 2 02-20-2011 11:43 PM
Confused about Converters DanielB Batteries, Univolts, Converters & Inverters 11 02-12-2011 08:32 AM
Confused. About the water pump? robwok 1960 - 1964 Overlander 3 02-07-2011 06:54 PM
