Old 02-07-2009, 12:15 PM   #1
Distantdrummer's Avatar
1975 31' Sovereign
Houston , Texas
Question Classified Ads Registration Question
I tried to do something (ask a follow up or somethin like that) over in the Classifieds and was told to register.
I made sure I was online over here on the forum and went back and was told same again.
Is the Classified part of the forums?
Isn't it owned & operated by Forum-Andy & his mods.
I guess it would not be wise to use the same password over there, eh?
__________________________
____ d'drummer ____
...aahh..rumm..pu..tum..tummm...
Distantdrummer is offline   Reply With Quote
Old 02-07-2009, 12:34 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I am not completely up to speed on the current software, but my understanding is that classifieds are run as a separate section, so yes you do have to sign in, however it uses the same sign in and password as the regular forum.
Aaron
WBCCI #XXXX AIR #2495
Old 02-07-2009, 01:09 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Originally Posted by wahoonc View Post
... so yes you do have to sign in ...
Exactly right. The login link is in the upper right corner. The classifieds software isn't seamless but the odd thing is if I log off over there, it'll log me off forums (at least with my browser settings). So, if I want to stay online at AIR, I just close the classifieds window when done.
5 meter Langford Nahanni
Old 02-07-2009, 01:11 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
That's happened to me a couple of times when we were asked if we wanted to renew our ad in the classified section... even if I was on line with the Forums, the classified section asked for a log in. As I understand it, the classifieds are a different section but under the same "umbrella" as the Forums.
TB & Greg and Abbey Schnauzer
#3954
Old 02-07-2009, 01:24 PM   #5
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
That's rather odd..I was able to go back and forth with no sign in other than the original first time sign in..
For example..
I just now clicked on the classified button while on the forum and, the browser open a new link..went to the classified add section and, it shows me signed in..I was able to move all over the classified section with not a signle prompt to log or sign in..
I am using Firefox version 3.0.6, as if that makes any difference.
I clicked on a non specific ad and, was able to leave a comment or edit it under my sign in user ID..
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 02-07-2009, 01:46 PM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
For example..
Have you signed into the classifieds previously? You may have a cookie left from the previous visit. I tried it in Opera, IE7 and FF3 all required me to sign in on the first visit but not additional ones, unless I signed out.
Aaron
Old 02-07-2009, 01:49 PM   #7
1984 29' Sovereign
Savannah , Missouri
Aaron
Never even occurred to me as it's been quite awhile since I was there last..
Let me try..
OK, here's what I found..
I went back over.."logout" from the classified and, then came back here to the forum.
No sign in required during that process. Went back to the classified, aha..it asked for me to sign in..
Came back here after signing in..
So, apparently it keeps a cookie for quite some time..
Interesting that, since I know I have run a number of programs (at one time or another) to clear out cookie..
Guess the best cookie remover is located right at the browser itself..
Hey, I have no problems~!!
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 02-07-2009, 04:37 PM   #8
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Nothing like stale cookies...
Aaron
Old 02-24-2009, 07:47 AM   #9
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
still cannot get in...
I still get this...........
Only registered users can contact sellers. Please · register so that you can safely contact other users.
I tried to log in using Forum info. ...won't work. I hesitate to reregister in fear of jamming up the whole system or loosing my previous info...What to do now? to be able to answer want ads? Thanks.
Old 02-24-2009, 09:19 AM   #10
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Melody Ranch, In the upper right corner on the Please register screen (After you select contact seller) you need to use the login tab. Then a screen comes up for you to enter your user name (mine already is in the block) and password (which is the same as your forums password). Hope this helps. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 02-24-2009, 11:50 AM   #11
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I am unknown
Ed,
Thanks, When I go to the log in page it is blank. When I put in my user name I get....
This user has not registered and therefore does not have a profile to view.
Back to square one....? Any more ideas out there?
Old 02-24-2009, 12:09 PM   #12
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 90
When you login be sure you have your username and password exactly right. They are case sensitive.
The login link is here....
Name:	classifieds login air.jpg
AirForums Custom Search
Janet H is online now   Reply With Quote
Editing classified ads Ahickpoet Forum Admin, News and Member Account Info 9 10-30-2011 10:50 AM
Classified ads gone Kristi Foster Forum Admin, News and Member Account Info 6 12-11-2008 11:46 AM
Who polices the classified ads? Rog0525 Forum Admin, News and Member Account Info 12 04-29-2007 09:48 AM
Classified Ads Happycampers Off Topic Forum 3 03-02-2007 07:03 AM
Classified Ads loafinow Forum Admin, News and Member Account Info 3 06-07-2006 08:46 AM
