Old 07-02-2011, 07:39 PM   #1
Air Mobile
2005 25' International CCD
Newport News , Virginia
Question Change user name?
Can I change my user name from tsupler to something else? If so, can someone shoe my how? I have tried a few times to no avail.
Tim
Tim_S is offline   Reply With Quote
Old 07-02-2011, 07:42 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
when you are viewing this screen and logged in select "user cp" in the upper left corner. then select "edit your details"
Old 07-02-2011, 08:38 PM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Tim
Your user name was made a permanent part of your account when you signed up here. If you want to change it, you will need to contact a moderator and ask them to do it.
Old 07-02-2011, 08:55 PM   #4
Kevin245's Avatar
Tim
Tim,
As Terry indicates, you'll need to go through the staff for this request.
Use the "Contact Us" button located on the bottom tool bar to send a request.
Eleanor Roosevelt
Old 07-02-2011, 10:33 PM   #5
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
I changed mine a while ago. It's a little bit of work, but it can happen. Just follow Kevin's lead.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
Old 07-03-2011, 08:50 AM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Incorrect Info - Sorry
I apologize for posting incorrect info.
I thought I changed both my user name and password without help a while back, when I returned after I was away from this forum for an extended period. I must have asked a moderator for help at that time, but I do not remember doing it!
Old 07-03-2011, 12:04 PM   #7
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
Tim
Is it me or what. Tim S is asking how to change his name here from tsupler to something else. Tim you are signed in as something else! ??
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 07-03-2011, 12:59 PM   #8
Kevin245's Avatar
The OP's first post was under the old name (tsupler). When the name changed occurred the original post name changed to the new name and now shows as Tim_S.
Eleanor Roosevelt
Old 07-03-2011, 05:29 PM   #9
Venice , Florida
Images: 14
That is very cool.
Airdreamers
WBCCI #8880
AIR #41310
Old 07-04-2011, 06:00 AM   #10
Air Mobile
Good job
Quick work, as you noted I am now reporting as Tim_S
Thanks for advice and thanks for the quick fix
Old 10-05-2011, 11:18 AM   #11
txwineohs
j c , traveling
Trying to change mine right now by following the 'contact us' link. Will post what happens
2txwineohs is offline   Reply With Quote
Old 10-06-2011, 05:08 AM   #12
Air Mobile
Worked for me, I am very impressed with this forum...very impressed
22' Dinette change to L-pull out 05ModPod 2002 - 2005 International 12 11-03-2016 03:09 PM
Change Storage Battery roger59 Sprinter and B-van Forum 4 08-17-2011 08:04 PM
Change 2004 Sprinter Grill to MB roger59 Sprinter and B-van Forum 10 04-19-2011 06:23 AM
