A dire concern for this camper also - the colorful display below my name is merely the path dragged over by a very rank 'Aluminum Albatross', since reaching my driveway it was moved once to clean the waste tanks and has been on blocks since.... Other than the pride of not getting totaled by kamikaze Lake Erie deer, or wrecking during downtown Chicago detour I have zero pride in traversing those States....
What is the convention for using those little maps for one's Avatar:
States you visited with or without your Airstream
States you have driven in with your Airstream
Only states where you have overnighted with your Airstream
Or 4. What ever you want it to be. I'm sticking with states I have actually camped in - same with my stick on version I have on the inside of my door on the Caravel. Have fun with it. Here is the link:
Wabbiteer took my thunder. I was going to say the convention includes a clause that Wisconsin can not be marked. Each time I see one of those maps my eyes go directly to my great state and see it has been avoided. Some will even have the states of Minnesota, Illinois, Michigan, and Iowa darkened with Wisconsin blank. I was convinced that the map did not allow the user to mark off the state of Wisconsin since I know that would be the first place to visit especially before Iowa.
I think the rule should be -- only states you've camped in, with your current rig, and with your current set of tires.
Actually, I like clancy_boy's rule #4. Make it whatever you like. Not everything in life needs a rule.
Dave
DayStreamer
2001 19' Bambi
02 Avalanche
I went to Visited States Map and filled in a map and saved it to my computer. The size is 198x 100 and it was 6.17 kb. When I tried to add it to my avatar, I got an invalid message. What went wrong? How do you get it below the 100x100 size? Do you edit it with photo shop? If so, I'll have to do it tonight 'cause I don't have PS on this computer.
Family of Disney Fanatics
WBCCI# 4821
Well, after some manipulations with MS Office Picture Manager I got something that worked for now. I may try something else later, though. I don't have the full map; I'm missing Alaska. That's OK since we haven't camped there, but It does look like I'm missing something compared to others.
WBCCI# 4821
i don't have alaska on my window either... i figure if i make it that far north, i'll rivet a brass one on the side... that's a REAL trophy... sorta like hawaii....
