Old 05-16-2019, 03:43 PM   #1
2016 30' Classic
Fort Meade , Maryland
Auto Zip Dee Awning Not Doing Anything
I've have a 2016 Classic. Upon dewinterizing last week, it won't open, doesn't even try to open. The control board says "closed." If I hold down on the Open button for a few seconds the light will go back and forward between Closed and Open. Anyone else ever had this problem? I'm camped in a state park now with no connectivity. I called zip dee and they said to try again when on shore power. That didn't help. I called again today and they said to check the ether wire under the sink. I'll try that when I get back to the campsite. They said if that doesn't work, to call back when I'm in the trailer and have cell phone connectivity so they can "trouble shoot." Anyone else ever had this problem?
Stews is offline   Reply With Quote
Old 05-16-2019, 05:11 PM   #2
2017 25' International
Kirkland , Washington
I had the same problem. I've got a 2017 which has the later box under the sink. Called Zip Dee but that didn't help. Suggest you press the close button and then the open, try doing that a few times.
ratch is offline   Reply With Quote
RELAX 12v AUTOMATIC AWNING RETROFIT KIT by Zip Dee for Main Awning LaBigDogs Awnings 12 07-30-2013 02:02 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
zip dee awning will not roll floridartist Awnings 6 07-19-2009 12:04 PM
Zip Dee Awning Will Not Retract kennytheecat Awnings 4 04-06-2009 06:10 PM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
