Old 12-20-2003, 01:46 PM   #1
norbert's Avatar
1993 30' Excella
chicagoland , north of cheddar curtain
Images: 24
adding a quote to post
could someone clue me in on adding a quote; for instance, when i click on quote, the whole post shows up. what if i only want to piece of it?.... and on the the dashboard if i click on quote, i get a pop up window that sez "enter text to be formatted"
norby
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 12-20-2003, 02:10 PM   #2
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
When you click on the Quote button on another users post, you get the entire post you are replying to in between BOLD tags [ B ]. In front of that you get a short blurb about the post you're replying to between ITALIC tags [ I ]. All this is included between QUOTE tags [ Q U O T E ].
To remove parts of the original post that you don't want to quote, simply highlight what you want to remove by dragging with your mouse, and then hit the Delete key. Make sure you don't highlight and remove part of the BOLD tag on either end.
You can also insert the start and stop QUOTE tags yourself, before and after something you type in or copy and paste in, like:
Four score and seven years ago...
You can do the above by using the Quote button and typing in the text in the little box, or you can just type [ Q U O T E ] (without the spaces) at the start of the text to be quoted and [ / Q U O T E ] (without the spaces) at the end of it.
Hope this helps,
Maurice
Old 12-20-2003, 07:16 PM   #3
norbert's Avatar
1993 30' Excella
Images: 24
Re: adding a quote to post
norby
Old 12-20-2003, 07:27 PM   #4
norbert's Avatar
1993 30' Excella
Images: 24
Hope this helps,
four score and a partridge in a peartree
and then they ate cake
Old 12-20-2003, 07:41 PM   #5
norbert's Avatar
1993 30' Excella
Images: 24
all hail road king moe
just as simple typing my kname...
Old 12-20-2003, 07:48 PM   #6
norbert's Avatar
1993 30' Excella
Images: 24
my name is norby the all knowing all seeing.......
Old 12-20-2003, 08:38 PM   #7
2001 34' Limited
The State of , Ohio
Nuthin' to it!
Maurice
Old 12-20-2003, 08:42 PM   #8
2001 34' Limited
The State of , Ohio
Here's another one... if you copy and paste a table of data into a message, the spacing won't always come out right. For example:
Col1 Col2 Col3
Tom 1 2 3
John 4 5 6
Me 7 8 9
But if you put it in Code tags:
Code:
     Col1 Col2 Col3
Tom    1    2    3
John   4    5    6
Me     7    8    9
it will
Maurice
