Old 09-20-2014, 04:48 PM   #1
1966 17' Caravel
sonora , California
Water Heater for '66 Caravel: Model?
The few posts I've seen about replacing a water heater in a Caravel seem to conclude Atwood, not Suburban. Anyone have a specific MODEL Atwood heater that works well with a '66 Caravel (i.e, good fit) ?? Thanks in advance.
sierratony is offline   Reply With Quote
Old 09-20-2014, 05:19 PM   #2
Six or ten gallon?
Old 09-21-2014, 01:02 PM   #3
1966 17' Caravel
sonora , California
Water Heater
Andy, I guess six gals. I think the original in it now is five. Don't want anything that I have to chop up the trailer to make fit.
Old 09-21-2014, 02:13 PM   #4
1974 Argosy 20
Kooskia , Idaho
Any Atwood 6 gal water heater will fit, propane only or Direct Spark Ignition. You will have to run 12 volts to the unit and locate a switch somewhere if you put the DSI one in, but it sure is more convenient than going outside to light it.
The propane inlet location will be different though. You will have to either re locate the line to come into the new place above the floor or drill a new hole in the new heater and move the fittings to use the old gas inlet pipe location. I think it is better to relocate the pipe to the new location, but that is up to you.
Old 10-30-2014, 02:55 PM   #5
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
So what have you chosen?
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 10-30-2014, 09:35 PM   #6
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
I have an Atwood 6 gal. electronic ignition planned for the Caravel and it looks like I will have to trim the opening in the trailer a bit, but no real problems for a slide in fit. The gas line comes in the side rather than the bottom as on the old models, but with a new floor, that is no problem - drill where it needs to be.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 10-31-2014, 12:02 PM   #7
1966 17' Caravel
sonora , California
Caravel Water Heater
Thanks, all, for the replies. I have not done anything yet -- was doing prelim research for probable install in the Spring. I did confirm also, FYI, that Andy has the best price. Thanks again.
Old 11-09-2014, 08:11 PM   #8
1967 17' Caravel
Centennial (Denver) , Colorado
Suburban 6 gal 13 inch girth
I found the best fit for my 67 Caravel to be the 6 gal Suburban, i did the pilot lite 110v electric combination so never would need city electricity or battery to run on propane but still be able to plug into city 110v when available, it worked great on a recent 4300 mile trip of the west and only modest alum trim was necessary around front of heater and i retained original outside cover placement.
jskalet is offline   Reply With Quote
caravel
Atwood Water Heater Model G10B for parts Support Admin Airstream Classifieds 1 10-22-2013 09:47 PM
What Water Heater will fit a '66 Caravel? sierratony Water Heaters, Filters & Pumps 0 06-25-2009 03:18 PM
Looking for Bowen water heater access door cover for '65 Caravel teeraniti Exterior Storage Compartments & Access Doors 4 06-15-2009 02:34 PM
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
1965 Caravel Water Heater flashgrbiv Water Heaters, Filters & Pumps 3 04-29-2008 08:33 PM
