Old 06-21-2016, 04:42 PM   #1
1967 17' Caravel
sonora , California
Waste Pipe Move
Has anyone modified the blackwater/waste discharge pipe so that instead of dumping straight down about 12-inches from the side edge of the Caravel?
I'd like to put an elbow (?) on mine and run a pipe out to the side of the trailer. Suggestions anyone?
tonyseidel is offline   Reply With Quote
Old 06-21-2016, 06:08 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
We redid our 31 Sovereign to dump out the side. Makes life easier and we were redoing all the plumbing anyway.... It's in our thread : Little Girl.
Kay
Old 06-22-2016, 01:21 PM   #3
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
There isn't much room for an elbow on the back there. It can hang down enough that you have to be careful not to tear the pipe off if it hangs down. There is also the problem that the bottom of the frame member is about even with the outlet for the waste valve. Measure about 3 1/2 inches down from the bottom of the frame and that's where your waste pipe will be if you run it to the side.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
West Boondocking Waste Water and Food Waste Disposal Ray Eklund Boondocking 2 10-18-2015 02:38 PM
Small drip from outside of waste pipe c_lewis77 Waste Systems, Tanks & Totes 4 08-06-2011 06:27 AM
Waste (Black Water) Waste Management Snaken49 Waste Systems, Tanks & Totes 4 07-08-2011 10:37 AM
Waste Water pipe cap - 1964? RetroTrailer 1960 - 1964 Globetrotter 2 02-21-2008 12:06 AM
Waste pipe cap flitzwhopper LP Gas, Piping, Tanks & Regulators 2 11-04-2006 06:01 PM
