I had a impulse buy this month and can't wait to get it out for a few days. It is very clean and original and I was told it had been caravaned to the Yucatan. Purchased new on Feb.23rd 1967 at Larry Barnes Travel Trailers of Nampa Idaho. It has every manual,warranty card ect... from it's purchase. I have some questions about some holes in the front and wondering if there would have been some plaques in those places? If so what are they and Are they repoped? I will post some pics.
Any comments are appreciated.
thanks, Ben
Hole up front was probably a front mount TV antenna, our 66 had holes there and a few remaining brackets etc. Interior looks to be in great shape, axle looks as shot as the one on our 63. I'd imagine with as low as the trailer is setting you'd have a difficult time getting a tire off. I have skin repair to do where the PO had to change a tire and even after deflating the tire couldn't get it all the way out without bending the base of the wheel well.
roof locker tracks (plastic) square cornered astrodome screen 63 refer, or at least the original door insert 2 12v hehr motors (working) w/ or w/o fan blade
Not placard mount holes. My guess is that they are for an antenna mount of some sort.
Expect a note from Andy about the appearance of a settled axel in your side picture. (been there too.)
It really looks nice!
Yes, those holes once housed a crank-out T.V. antenna. Ben, in your third photo (interior) there should be a hole to the left of the front window (maybe hidden by the curtain) where the crank would have been.
Except for the a.c. and what looks like a wooden access door under the bathroom sink, your '67 is identical to ours.
Our wheel well was modified (trimmed back a bit) to make it easier to change tires. Axle is in fine shape, but not much room to work under there.
__________________ "Reality Is The Leading Cause Of Stress"
"There are only five great men in the world and three of them are hamburgers."
Hi, is your axle in fine shape ? or by appearances is mine in fine shape?. I want to inspect camber and could even have spindles magnafluxed for cracks. What sort of door for opening do you have under sink and also do you have the antenna that cranks out and so any pics?
thanks, Ben
Congrats, that looks like a real find! Very original inside
We replaced our axel after we discovered it gave the trailer a rough ride and rivets were popping, things were getting rearranged inside during trips. I think it had to do with the broken frame welds I had to fix later as well. We had a local RV shop put a dexter on it, new hubs and brakes, and have been very happy with it.
When we got it lots of folks told me I'd get tired of it and want to upgrade to something bigger, but we've had it for five camping seasons and we still love our Caravel!
The main reason some people will tell you you won't like a small trailer, is because they wish they had one to tow around themselves.
Cover those holes up ASAP....aluminum tape works well. Just temporary.....water gets in there and then the fun begins.
That antenna mount does not appear to be the crank up TV type. There is no hole and gear showing either outside or in. I think it was just a generic radio antenna,,,,the type that has two mount sites about 6 to 10 inches apart on the antenna "rod." I had one on my 69 Caravel and see them on the 70's Airstreams every once in a while. I think you can look thru JC Whitney or go to a NAPA type store and get what you need.
I replaced the axel in the 66 with Henchen. Its nice. I replaced my latest axel with a Southwest Axel and wheel/brakes for 30% of the Henchen cost. Its really nice.
thanks, Ben
The following article will help you check the axle out yourself.
