Old 05-21-2010, 03:06 AM   #1
Maeffy's Avatar
1967 17' Caravel
Wolfurt , not from US
My '67 Caravel work in progress
Hi everybody,
I wanna share what i have done since 6 month.
1Pic: some rust, but not so bad.
2Pic: trailer hung down 2" so i decided to do some metal work
3Pic: straightening in progress. with a belt and a piece of wood
4Pic: I weldet an area for the fresh and grey tank next to the axle
5Pic: Hot-dip galvanized and painted
6Pic: new ground floor
7Pic: Insulation and moisture barrier for the belly pan
8Pic: banana wrap on the rear corner
This weekend I am gonna build both together again...
Thats it. A lot of work but I am seeing a light at the end of the tunnel
Maeffy
ID:	102994   Click image for larger version
ID:	102996   Click image for larger version
ID:	102998   Click image for larger version
ID:	103000   Click image for larger version
Maeffy is offline   Reply With Quote
Old 05-21-2010, 04:43 AM   #2
OO , OO
Send a message via Skype™ to cruiser54
In 6 months.... ah! Great work, I do handicraft also with pleasure. But if I fancy how long it lasts to the AS is restored!!?? My Cruiser stands with airstream4u in Hamburg and there many people work on it. I am at an age where I to me must already consider whether I do this to myself. I would like to experience to travel around with it! I makes the inside removal of wood, pleases me about it.
A lot of fun in the other one work wishes you
Werner
cruiser54 is offline   Reply With Quote
Old 05-21-2010, 06:07 AM   #3
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Beautiful!
Very nice work! I hope to see it in person someday. Please keep us informed as you progress.
Old 05-21-2010, 06:38 AM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Very nice work! Question: In picture 7, there are two things that look like tubes running from the front to the rear. The one on the right in the pic looks like flexible electrical conduit. Is it? What's the tube looking thing on the left? It looks too small to be an LP line.
Chris
Old 05-21-2010, 08:21 AM   #5
Maeffy's Avatar
1967 17' Caravel
Hi Chris,
Yes, its a electrical conduit for the mainpower from my car. The left one is for gas. It must be one peace in the undershelf ...
The same system is used in the rear. One is for the power cable and one tube is for city water. All are ending in the water tank area behind the axle...
Maeffy
Old 05-21-2010, 08:52 AM   #6
Originally Posted by Maeffy View Post
Hi Chris,
Maeffy
Suggestion.
Change the shock bracket setup for the horizontal shocks.
That will eliminate chasing around for the correct vertical shocks.
Old 05-21-2010, 09:24 AM   #7
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Nice work so far!
Stephanie
Old 05-21-2010, 09:43 AM   #8
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
Hi everybody,
Maeffy
Looks like you are really starting over from scatch!
Just a few questions?
Can you explain the hot dip galvanized process? Was the entire frame dipped in a giant vat of hot paint?
Also, what would prevent the moisture barrier from also trapping moisture INSIDE the bellypan area?
Gary
safari62 is offline   Reply With Quote
Old 08-16-2010, 02:08 AM   #9
Maeffy's Avatar
1967 17' Caravel
Hi Gary,
Hot dip galvanizing is a zinc wire melted with arc load and sprayed with air pressure on the frame....
Nothing i did, was made by a trailer manufacturer.
rgds,
Maeffy
Old 08-16-2010, 02:17 AM   #10
Maeffy's Avatar
1967 17' Caravel
Bellypan is done....
Old 08-16-2010, 04:17 AM   #11
OO , OO
It is a pity, one does not see this after!
Greetings Werner
Old 08-16-2010, 05:19 AM   #12
Maeffy's Avatar
1967 17' Caravel
Hi Werner
That's true, most of them i did until now isn't visible.....
Maeffy
Old 08-25-2010, 11:07 AM   #13
Maeffy's Avatar
1967 17' Caravel
Smile Look what I've found...
I found something strange
Someone, I guess @ Airstream limned this to the inner cover.
What does he want to tell me ?
Funny...
Maeffy
ID:	109329   Click image for larger version
ID:	109331   Click image for larger version
Old 08-25-2010, 11:16 AM   #14
Maeffy's Avatar
1967 17' Caravel
I am On TOP
Basic polishing and 4 holes for the AC.
Next foto is the frame between outer and inner cover...
Maeffy
ID:	109333   Click image for larger version
caravel
Caravel :: 1967 Airstream Caravel C Johnson Airstream Registry Discussions 0 08-19-2011 08:31 AM
'78 Argosy 27' a work in progress :: 1978 Argosy/Airstream jjustice Airstream Registry Discussions 0 08-19-2011 08:30 AM
Airstream) WORK IN PROGRESS eBay Watch Airstreams on eBay 0 05-30-2011 06:00 PM
