12-07-2004, 10:42 PM
#61
1968 17' Caravel
Battle Ground
You know, I'm not as scared of the idea of doing the full monty to it as I was, especially having seen Malcolm's project. My 14ft interior seems like it would be a cakewalk compared to his 31ft trailer!
I'm working my way towards the back and seeing what I find. The fridge is out now, I'm taking the kitchen cabinet out next, and then probably the closets and we'll see how the bathroom looks. I know at least on the last trip the black tank filled up and there was some brown water on the closet floor, which I suspect means a gasket is bad somewhere between the toilet and the tank - yuk! So the toilet needs to come out anyway.
I'm hopefully going to get the bellytank open this weekend (if the rain stops for a day) and see if there's any rot under the bath. If there is, then the whole thing is coming out and a new floor is going in end to end. No foolin' around. I don't want to do this job more than once. And a nice side effect would be getting rid of that 'old trailer smell'.
I'm thinking any floor replacement I do will be with the polyboard like Malcolm is using. He's already done much of the homework, and I was very impressed with the part he had in when I went to visit.
Stephanie
12-08-2004, 07:06 AM
#62
Somewhere between NY & LA
Good Morning Stephanie,
It's fun isn't it? A combination of demolition, archeology and renovation. Very satisfying, even though it NEVER goes the way we think it will.
My first trailer was a 1966 Caravel. I had that thing apart several times, I even took all the interior skins out to do rib work. What a nice little trailer. I sold it to a movie company in a moment of weakness. I later found out they CUT IT IN HALF to make an interior set. Disturbing behavior from Hollywood!
I now own a 1963 Globetrotter and my saga is much like yours: One day when I was gloating over having bought a pristine, untouched, origional owner trailer, I decided to look under the cabinet in the bathroom.....
As others have said, it must have been a subconscious desire for the "full monty." You know the rest...
One thing I did when I had the floor out was to strip and polish the lower wall in the bathroom- from the floor up to the first rivet line. Maybe two and a half feet measured vertically. It really makes the bathroom look cleaner, and was easy to do standing on the ground with everything out. I forgot to take pictures of that when I was making my album. I'll add them later so you can see what I'm talking about.
This is also a great time to give some serious thought to wiring. Real easy now to snake all those cables for the complicated multi battery/solar system you WILL install later!
Best of luck to you.
12-08-2004, 09:50 AM
#63
1956 22' Flying Cloud
Durango
Having done a full floor replacement - its not that bad - a bit time consuming, but not that hard. Then while you have the frame exposed, you can give it a nice coat of paint - and bing a bang a boom your good for another 30-40 years. I'm not a beliver in doing the small patch thing - just as easy to do the whole thing. In my 58 the floor was not rotted, but the bolts had loosened/pulled through - everything is nice and tight now.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
12-08-2004, 10:29 AM
#64
1975 Argosy 26
1963 24' Tradewind
Seattle
A "trailer raising!"
I sense an "upcoming" forum event! Seriously - Steph, are you planning on doing a shell off, or replace what you can with it on? Vancouver WA can't be that far from us, if you need muscle, let us know.....I'll send my wife!
Actually, she'll be out of commission after her surgury for awhile, but I am willing to help out.
Marc
12-08-2004, 10:37 AM
#65
Putnam
, Connecticut
The Caravel should be a good training ground for that overlander you buy next. I also have an 68. There is a unique feeling to them for those of us who were tent campers. Replacing the aluminum wire with copper would be a good idea if you take the lower panels off to do the floor. Not much wire in a Caravel. Getting the stuff out from under the floor will change how it smells for sure.
12-08-2004, 10:43 AM
#66
1968 17' Caravel
Battle Ground
Thanks all, for the words of encouragement (and a good laugh from Marc) I'll be calling when the heavy lifting comes!
Courtney, the thought of someone cutting a Caravel in half breaks my heart! Funny the hubby and I were just talking about how Hollywood buys and destroys cars that I save up for years to buy. I think the Thelma and Louise Square-bird got me started. But cutting up a Caravel? Argh!
I think I can do the replacement with the body in place, just braced and supported. I'm hoping it's something I could do in pieces. Take out the wood in front, fix and paint the frame, put new floor in, move to the next piece back, and repeat. It's a real patchwork under there right now.
Hey, no rain today, I'd better get back to it!
Stephanie
12-08-2004, 12:49 PM
#67
1973 31' Sovereign
Portland
, Oregon
Stephanie,
I would be happy to help you strategize on a Polyboard floor replacement. I do think you can do it a few steps at a time if you want to. It is also not that bad to take the whole floor out and do each step completely before moving on to the next one. I am completely convinced that a full body off remodel is only really necessary in the more extreme cases where a frame needs to be taken somewhere else to have work done.
Malcolm
12-08-2004, 01:39 PM
#68
1968 17' Caravel
Battle Ground
Thanks, Malcolm, I'll definitly take you up on that offer. Think I can have this whole thing done in time for camping in the spring?
Stephanie
12-08-2004, 02:30 PM
#69
Durango
Yup I would go for it and take out the entire floor first - at least that what I did - you should fit front and rear sections first - those are the hardest, then fill in the middle.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Rally
restoration rally
12-08-2004, 04:44 PM
#70
1973 31' Sovereign
Portland
, Oregon
Stephanie,
About how long is your trailer on the inside at the floor level? Polyboard (and plywood for that matter) comes in 4' wide sheets (of course). On my 31' I have about 27' inside at the floor line. This translated to 7 sheets of Polyboard - one of them getting cut down to 3' wide. I was actually able to use the remainder for making shims for the cross members at the plywood joints that are lower by 5/8". You may not know yet if your has this but it will be important to find out at some point.
Malcolm
12-08-2004, 04:53 PM
#71
1973 31' Sovereign
Portland
, Oregon
Stephanie,
It should be possible for you to have it all done and back together in time for spring camping. It does of course depend on what has to be done to the frame and how much time you have to put in on it. My progress is pretty slow right now partly because of extra Christmas season tasks and partly because I am too busy with other stuff much of the time normally. I do have 4 of the 7 Polyboard sheets installed now and the next sheet is cut and ready to go in. If I can get some time this weekend I think I can get the rest of the sheets all in place. I will have to spend a little more time to finish bolting and screwing down everything. That will be a great feeling to have the floor all back in again though. Let me know if you want to come down and take another look at the details.
Malcolm
12-08-2004, 05:13 PM
#72
Putnam
, Connecticut
The hard part will be dealing with the bathroom pieces without breaking them. I don't even see how it all comes apart.
The front is supported by the plate welded to the front crossmember and riveted to the exterior shell. This holds up the front of the Bat Cave just fine with the floor out. I have the front and back floor and all but the edges of the rest out and the shell is like levitating. Held up by the plate in the front and some mid section ribs on pieces of the floor. I'ld do the front first. Good time to replace the wire harness when you have the floor off as it's under the front curbside.
Are you going to add a grey tank or larger black tank?
12-08-2004, 07:32 PM
#73
1968 17' Caravel
Battle Ground
I don't want to make the project anymore complex than it already will be, but I would very much like to add a grey tank while I have it all apart. However, using the blue tank has never been that big a hassle, so it is not a necessity. I will be upgrading the Univolt, rebuilding the Hydroflame, and maybe doing something about the non-working fridge (a new fridge is starting to sound pretty good). Oh, and fixing the toilet to black tank connection - ewww.
I finally found a seam in the floor under the vinyl, so I will continue to scrape up the vinyl along the seam. I figure there's no point in killing myself off scraping up vinyl on wood that is going to get cut out anyway. The vinyl is coming off very slowly, in small pieces, and it's extremely tedious work on my hands and knees - gets old fast!
Stephanie
12-08-2004, 11:49 PM
#74
1968 17' Caravel
Battle Ground
Here is a picture of today's progress. About an hour on my hands and knees revealed the entire first seam, and I marked the bolts and metal squiggly things as I found them.
Does anyone know if there will be bolts in the center of the floor panel as well, and approximately how far between them?
The area outlined in red is the big rotted area under the battery compartment. The area outlined in Blue is where I have found patches done by a previous owner.
My husband thinks I am in over my head. He's really going to freak when I pull the bottom wall panels off. I think he thinks that this did not need to be so involved a project just to patch the hole by the battery compartment. But he should know that I will never be happy knowing I only did what I HAD to do, not what I think I SHOULD do.
Stephanie
12-09-2004, 01:06 AM
#75
1973 31' Sovereign
Portland
, Oregon
Stephanie,
There will be fasteners of some type in the middle of the panels. On mine it seemed like a PO must have replaced a lot of the floor since I did not find elevator bolts for the most part. Instead I mostly found self taping screws. From what I can tell all of the fasteners were origianlly into the cross-members and not into the length-wise frame members. Also I found that I could not actually unfasten most all of the fasteners. I had to cut them off instead. If your floor is still held down by elevator bolts I think you will find that the factory bent them on the underside to keep the nuts from working loose. While that does work it also makes it virtually impossible to unbolt them. The main point here is that you might very well be wasting your time trying to uncover all the fasteners by removing the floor covering.
I removed most all of my old floor using a technique I read about here on the forums. What I did was to use my circular saw with the blade depth carefully set at just a hair less than the plywood thickness. I used it to cut out big rectangles of the plywood between the cross members and as close as I could get to the body around the outside. Since there were no fasteners into the length-wise members the pieces I cut could be popped out with a little pursuasion from a crow bar and hammer. I tried to cut about 1 " from the center line of each cross-member so that the piece of plywood left bolted to the cross-member was roughly 2" to 3" wide. I generally could cut within an inch or so of the bottom of the body. I also cut the plywood across the ends of the strips that were over the cross-members at their ends near the body. I then worked at cutting the fasteners that held the strips of wood to the cross-members. I was able to use a reciprocating saw for most of that process. I found it helped a lot to pry the wood up a little with a crow bar. I also discovered that there was a layer of compressed fiberglass between the wood and the frame that made a little gap that the saw blade could fit into. I used some of the plywood rectangles turned side-ways as platforms to kneel on after I cut them out. By the way if you don't allready have some it is well worth getting a good pair of knee pads. I found some at Home Depot that are a fairly soft rubber that actually grip the surface I am kneeling on fairly well. They worked well when I was on the roof putting in my Fantastic vents.
I suggest that you remove the bottom strip of wall before you cut out the floor. It is much easier to do while you have something to stand on. I also suggest that you consider putting in the bracing like I used at least before you start removing the plywood that is around the edges below the body. I would do it sooner than that if the plywood is rotted a lot around the edges so that the body is held in place while you work.
There is a bunch of detail about the above steps in the following thread - espcially #74.
http://www.airforums.com/forum...ad.php?t=11814
Make sure you take a lot of photos as to where things are before you take them out. I also made a diagram of where all the holes and notches were in the floor before I started cutting it all up. I made templates for the curved ends using cardboard while the body was still held more or less in its original location.
Malcolm
12-10-2004, 01:50 PM
#76
1968 17' Caravel
Battle Ground
Ok, so today I'm working on taking off the bellypan, when the rains started up again. So I'm inside waiting it out. Here's my plan:
Finish removing the kitchen cabinet - the Hydroflame still refuses to budge, I think I'm going to have to hacksaw through the exhaust duct to get it out.
I checked out the interior lower wall panels and discovered there are only five of them (the joys of a small trailer). I'm going to clean them and then remove them and put them in a safe place.
Then diagram where the holes for the wiring in the floor go, so I can put them in the right place in the new floor. Also make a template of the front end curves while everything is still stable.
Then brace the body with 2x4s. Is there a problem with the door being opened and closed while all this is going on? Should I plan to brace the body in front of and behind the door in order to keep it lined up and working during the floor replacement?
Also, I am wondering about how I will get the new pieces of wood in. I can see if I take out the first two sections, then the front section can be rotated into place, but how do I get the second section in? Will it need to be in two pieces, so I can put in the left side and then the right side, with a seam down the middle?
There's still frame repair to worry about, but I'm thinking ahead, wondering how this is all going to work.
Stephanie
12-10-2004, 02:12 PM
#77
1968 17' Caravel
2005 30' Safari
Somewhere
, roaming America
Steph, you rock! Congrats on diving in there and doing the job right. We're rooting for you!
12-10-2004, 02:17 PM
#78
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Originally Posted by overlander64
Greetings Stephanie!
I haven't tried this method in an Airstream, but I did use this technique to remove sheet vinyl from my kitchen floor after the flood of 1993. I used a heat gun set on low heat with an extra-wide concentrator nozzle (about 3.5") to heat the vinyl ahead of a 6" heavy-duty paint scraper. It was still tedious work, but the heat would soften the mastic enough to release most of the tile and its backing. This is one of those methods that requires breathing protrection and good ventilation as the fumes can be noxious.
Good luck with your project!
Kevin
Kevin,
Now my brain kicks in (maybe from the fumes ) When I used to work in hospital maintenance we would replace damaged floor tiles using a torch and heavy scraper to remove the damaged tiles. Heat does do the trick. I would not reccomend the torch in the AS because of the wood floor. BTW the self stick tiles in my unit came right up with just a scraper; the glued down sheet goods required a scraper and heat gun and then only came up in small pieces.
Stef,
Good luck and I am watching to see where it all ends up. I have my front floor out and the new pieces cut, then I get to see where else to go from there. Probably by the door then on to the bathroom. I want to get this thing back on the road by February so I can live in it I did not find any fasteners in the main frame rails just the cross members. Mine so far have all been self drilling tapping fasteners. No Elevator bolts yet. The outriger bolts were installed from underneath. I had to cut all of my self tappers off, could not get a single one of them to back out even using visegrips and a torch.
Aaron
WBCCI #XXXX AIR #2495
12-10-2004, 04:56 PM
#79
1968 17' Caravel
Battle Ground
Thanks, Rich, hopefully your Caravel isn't next BTW, I got great inspiration just when I needed it from you. I was inside after an exhausting couple hours dissasembling the trailer and scraping up vinyl, thinking "my god, what have I done?", when I picked up the Airstream Life mag and re-read the article about your Argosy. The part about 'gumption blocks' did the trick. I decided I was not going to let it get me down, and just keep plugging along until it's done. Thanks!
Stephanie
12-10-2004, 05:02 PM
#80
1973 31' Sovereign
Portland
, Oregon
Stephanie,
You might be interested to know that there are only 5 lower wall panels on my 31' AS too. They are just very long. I did find that I could roll them up by the way.
Take a closer look at the photos and procedure that I outlined for the bracing and you will see that I used some 6" wide strips of 5/8" plywood as lengthwise strips sitting on top of the 2x4 cross braces. I did have a 2x4 near the front of the trailer and one just behind the door. Put the one across the door with the door closed. It will help maintain the alignement of the opening. The strip of plywood stabalized things OK but did get in the way of climbing in and out a bit. in your case you may be able to get away just fine with only two 2x4 cross braces. I would suggest putting them at the body bows that are just where the curved ends start to straigten out. I would also suggest a strip of 1x6 legthwise on each side. This would also allow you to span more than 8' if the 2x4's are further appart than that. Use self taping screws to attach the 1x_ at each body bow. Also make sure that the top of your 2x4's are just high enough to clear your wheel wells so that the 1x_ will also clear.
If you use the Polyboard I think you will be able to lift up the middle of the sheet enough to get the ends to tuck under the sides of the body. You can then set the middle down and it should slide into place. The Polyboard is heavy enough that this would best be accomplished by two people though. In my post about the Polyboard installation I noted that I decided to use 1/2 sheets so I could handle them by myself more easily. I put a spline down the joint which I attached with glue and screws. That approach seems to work fine too. If it turns out that you have 8' or less of the middle sheets you could also put them both in length wise with a seam down the middle.
Malcolm
