Old 08-06-2019, 07:57 PM   #1
SilverWind's Avatar
2017 25' International
1968 17' Caravel
Los Osos , California
How to Determine GVWR for 68 Caravel
I'm trying to determine the GVWR for my 68 Caravel. Airstream lists two sets of dry/hitch weights for the trailer, 2460/330 and 2340/270. They do not specify a GVWR or net carrying capacity.
I'm wondering if the Dexter axle weight rating along with appropriate tire pressures are the determining factors, or is there something else in play here?
The Dexter axle is rated at 3500 and is paired with Goodyear Endurance Tires which can be pressure adjusted for weight.
I weighed the Caravel, loaded for camping. With full water and propane, clothes, food, accessories etc. the trailer weighed in at 2950. Hitch/tongue weight, using two different Sherline scales averages 590 pounds.
The RAM 2500 weighs, front axle 4840 and rear 4860, loaded for camping. It is equipped with auto rear air leveling so no weight distribution system called for.
SilverWind is offline   Reply With Quote
Old 08-07-2019, 01:26 PM   #2
SilverWind's Avatar
1968 17' Caravel
To restate the question in general trailer carrying capacity terms. Does the axle weight capacity rating set the carrying capacity limit of the trailer or are there other factors about the trailer involved when determining how much you can carry?
Does it follow that the 3500 Dexter axle capacity minus 'loaded for camping' weight at the scales of 2950 mean that I have a 'headroom' of 550 pounds carrying capacity?
Old 08-07-2019, 01:44 PM   #3
kpm
2018 25' International
Mound , Minnesota
[...] The RAM 2500 weighs, front axle 4840 and rear 4860, loaded for camping. It is equipped with auto rear air leveling so no weight distribution system called for.
Air bags aren't necessarily a replacement for a weight distribution hitch. The loaded weight on the front TV axle should be 50-100% of the weight when unloaded.
kpm is offline   Reply With Quote
Old 08-07-2019, 01:52 PM   #4
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
As noted above 'auto-leveling' has little to do with WD.
It just negates TV rear end squat.
WD bars are what transfers the needed weight.
If you are not concerned with WD....ignore this post.
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 08-07-2019, 02:55 PM   #5
SilverWind's Avatar
1968 17' Caravel
WD is not a concern in this case.
I'd simply like to know how to calculate the net carrying capacity of the trailer.
Airstream did not state a net carrying capacity in 1968, only a 'weight'.
I only have the 'loaded for camping weight' of the trailer of 2950 plus the Dexter axle weight capacity of 3500.
caravel
Dexter says "subtract tongue weight from GVWR to determine Axle rating" GuitarmanFL Axles 8 11-18-2018 08:10 AM
How to determine Axle Ratio bocotim Tow Vehicles 9 04-10-2009 06:07 PM
Please help determine MAX running light wattage Westfalia Electrical - Systems, Generators, Batteries & Solar 4 01-17-2006 01:50 AM
How to determine waste tank levels? Janet H Waste Systems, Tanks & Totes 2 01-07-2004 04:13 PM
Tongue weight, how determine? pilgrim_still Towing, Tow Vehicles & Hitches 6 06-17-2003 03:45 PM
