I have a question. Can you use regular dump valves on the grey water and black water drain or does airstream use a special valves, also can you replace these by just lowering the pan covering the holding tanks? This is on a 1987 32' Excella.
On my Bambi, the valves are manufactured by Valterra, available from most any RV parts supplier and Camping World. Also, the valves are replaceable without dropping belly pan, as the fitting to the waste pipes is immediately behind the valve housing.
Rick Klein
Seeking another Bambi
'08 Honda Ridgeline
