Old 08-18-2018, 01:06 PM   #1
SilverWind's Avatar
2017 25' International
1968 17' Caravel
Los Osos , California
Guide to Replacing Shocks on my 68 Caravel
Hi. I'm looking for a Step-by- Step Guide to Replacing Shocks on my 68 Caravel.
Any input would be greatly appreciated.
SilverWind is offline   Reply With Quote
Old 08-18-2018, 03:02 PM   #2
SilverWind's Avatar
1968 17' Caravel
I've ordered the Monroe RV Shocks #555003 as recommended by Colin Hyde for this vertical installation.
We need to understand the basics of jacking and supporting the 68 Caravel while doing the job.
Old 08-18-2018, 03:08 PM   #3
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Corroded fasteners? PB Blaster is one of my regular helpers.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 08-18-2018, 03:09 PM   #4
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
Just bought 4 of these shocks from Amazon, best price I could find .
Joyflea is offline   Reply With Quote
Old 08-18-2018, 04:58 PM   #5
SilverWind's Avatar
1968 17' Caravel
Sorry. I'm not sure that I understand.
Old 08-18-2018, 05:22 PM   #6
Joyflea's Avatar
1967 26' Overlander
Alpine , Texas
PB is a spray that helps with rusted nuts .
Old 08-18-2018, 07:18 PM   #7
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Step #1: Safely lift and support your Airstream.
Step#2: Remove the tire/wheel assemblies.
Step #3: Unbolt the shocks from the shock mounts.
Step#4:Remove the shocks, using the shock itself to bend the axle shock mount outward slightly so it will clear the frame.
Step #5: Install the new shocks.
Step #6: Re-install the tires/wheels.
Step #7: Safely remove the supports, and lower your Airstream to the ground.
Old 08-19-2018, 12:04 PM   #8
SilverWind's Avatar
1968 17' Caravel
Do you put your safety stands under the (single) axel or under the frame ends?
Old 08-20-2018, 11:15 AM   #9
SilverWind's Avatar
1968 17' Caravel
Do you guys put your safety stands under the (single) axel or under the frame ends?
Old 08-20-2018, 11:37 AM   #10
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
I just did the shocks on our 1999 moho. (Old, dead Monroes replaced with brand new Bilsteins all around!) Often when replacing shocks, you need to squish the new shock down just a bit to do the installation. On the moho, the stabilizer shock didn't need it, but all four of the others needed about 3/4" of squeeze. It was HARD, but I discovered that we have the perfect tool for it. It's our inexpensive furniture clamps from Harbor Freight:
Lynn
WBCCI 21043
caravel
Step by Step: Replacing OEM skylights with new Custom Maxim Skylights Bambi_Bandit Roof Vents, Skylights & Fans 403 04-09-2019 09:31 PM
shocks or not when replacing axle on 65 Caravel nickoftime Shocks 6 11-23-2016 05:18 AM
new curtains for the 67 Safari... with a step by step picture guide customgrind Upholstery, Blinds, Walls & Interior Finishes 3 08-08-2010 09:23 PM
Shocks, shocks and more shocks Inland RV Center, In Commercial Listings 1 05-26-2009 03:37 PM
