Old 05-30-2011, 08:03 PM   #1
1966 17' Caravel
Santa Rosa , California
Wink Gray vs Black water
In this 66 caravel I ran the water and the water was pouring out the Dump tank. I just found a handle in the back compartmentover the bumper I assume is for the Black water Is it normal for the Gray water to just run out . I noticed the shower pan backing up so I unscrewed the outlet and it rean wiled Is this normal ? Or is there a shut off for the gray water as well . This is all new to me
Thank you
cedy is offline   Reply With Quote
Old 05-30-2011, 08:11 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Unless a prior owner installed a gray water tank, your Caravel does not have one. If not connected to a sewer in an RV park, owners without gray tanks use a blue tote such as: Tote-Along -30 gallon
Bill
Thank you
Just my personal opinion
Old 05-30-2011, 08:14 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Airstream didn't put gray tanks in until 1974. The gray water sure didn't end up in the black -- that would overwhelm it in short order.
Vintage folks can place a blueboy tote under the gray water drain. Dumping gray water on the ground is not permitted in most places. Still ... I'd say trickling sounds are probably pretty common after dark.
5 meter Langford Nahanni
Old 05-30-2011, 09:17 PM   #4
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
You can buy a cap for the outlet so the water doesn't trickle out. This will not contain much waste water and will rush out when the cap is removed. A handy bucket placed under the outlet will catch the little water. Get a cap that has a hose tap with it's own screw on hose cap so that you can connect a garden hose for the gray water. Do not dump the black water through the hose.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 05-31-2011, 08:16 AM   #5
1966 17' Caravel
Grayvs black water
Thank you all, very nice and helpful folks Bill that is a cute little car Is it a custom car? How does one put a photo of a car or trailer on the Profile?
Old 05-31-2011, 08:29 AM   #6
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Cady,
The car is a stock 1977 Lincoln Continental towing our Safari. Regarding the picture, go to User CP and under user profile on the left side you will find the tab to insert a profile picture.
Bill
Black water tank removal 1975 Mus289 Waste Systems, Tanks & Totes 7 04-17-2017 08:27 AM
Waste (Black Water) Waste Management Snaken49 Waste Systems, Tanks & Totes 4 07-08-2011 10:37 AM
Noobie black water question pappy19 Waste Systems, Tanks & Totes 9 05-25-2011 09:52 PM
Combining Black and Gray Roof Vents for 1958 mello mike Roof Vents, Skylights & Fans 5 02-06-2011 12:50 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
