Old 06-20-2016, 07:32 PM   #1
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Cleaning Vinyl Walls
I scrubbed all of the wall panels for the trailer this afternoon.
With the help of some Marine Clean mixed 1:1, a scrub brush mounted on a stick, the garden hose and elbow grease the panels are ready to go back in.
With any luck by the 4 th of July.
There is light at the end of the aluminum tunnel. ☺
ID:	264856   Click image for larger version
ID:	264858   Click image for larger version
Dingo Girl is offline   Reply With Quote
Old 06-24-2016, 09:40 PM   #2
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
Magic Eraser works well, too. Handy for those panels you don't want to take out but do want to clean.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 06-25-2016, 07:15 AM   #3
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Thank you for the tip. I will try that on a couple of stubborn spots.
Some decades old Filth does not want to let go.
Old 06-25-2016, 08:12 AM   #4
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Are you going to eventually paint your panels? If you do, I would rinse them again with a cloth and water before painting, just to make sure there's no left over residue from the cleaner. That way the paint sticks. You definitely DON'T want to do it twice!
They look very good, by the way. I did the same thing when we had ours out in our reno. We had them rolled up for a year before they went back in! Good luck with it all!
Kay
Old 06-25-2016, 03:38 PM   #5
Argonaut20's Avatar
1966 17' Caravel
The panels you did look great, by the way. I had some spots and stains that I could not get out no matter what I used and no matter how hard I brushed. The clean walls looked so good when I put them in that I don't really notice the few spots.
2006 Toyota Tacoma
Old 06-26-2016, 04:31 AM   #6
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I won't paint them. I think they are good enough to put back in as is.
I really was shocked at how clean they came.
I'm not putting the plastic bathroom back in mine and was worried the vinyl coated panels under the plastic were too far gone and would never come clean. They cleaned up beautifully and can be reused.
There is some wood stain (minwax etc...)on one panel and not sure how to get that off without removing the vinyl with it
I wish the PO would have taped off what he was staining.
Any ideas on how to remove the stain??
Old 06-26-2016, 03:23 PM   #7
Argonaut20's Avatar
1966 17' Caravel
You might try Goof Off, but it could damage the vinyl. I'd try a very small, out of the way, spot first.
Not putting the fiberglass bath in?
2006 Toyota Tacoma
Old 06-27-2016, 03:36 AM   #8
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I'll pick up a can after work and try it.
Nope no plastic /fiberglass bath going back in. I really don't like the look of it.
I will have a sink and toilet.
Old 06-27-2016, 08:19 AM   #9
Argonaut20's Avatar
1966 17' Caravel
You may have saved yourself some trouble by not putting the fiberglass base back in. I found it ... er ,,, challenging. PITA in other words.
2006 Toyota Tacoma
Old 06-27-2016, 10:24 AM   #10
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I can see it being a PITA.
Not sure if I should keep the original bath just in case when the camper is sold at my estate sale that the new owner may want it.
I will be dead and gone.
Or do I not care about the future of the trailer?
What have others done ?
Old 06-28-2016, 06:25 PM   #11
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
Krud Kutter
4RXLA is offline   Reply With Quote
Old 07-24-2016, 06:49 AM   #12
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
The previous owner stained the piece of wood above the sofa cushions but failed to tape this off or just remove it to do the staining.
Any ideas on how to remove wood stain from my vinyl walls with out removing the vinyl?
Stripping interior vinyl covered walls Anna Upholstery, Blinds, Walls & Interior Finishes 87 10-12-2014 03:39 PM
Best way to remove Vinyl from interior vinyl clad Eric H General Interior Topics 11 10-21-2013 11:32 AM
Roll Vinyl vs. Vinyl Tile in Bathroom? Roadrunner Repairing/Replacing Floor &/or Frame 6 09-29-2011 07:23 AM
new vinyl over vinyl cabinets? Aage Cabinets, Counter Tops & Furnishings 28 09-29-2009 07:50 AM
vinyl tile vs. one piece vinyl loki Repairing/Replacing Floor &/or Frame 69 02-18-2007 03:38 PM
