Old 03-16-2004, 04:30 PM   #1
Over59's Avatar
Putnam , Connecticut
Images: 37
Caravel Tires
Turns out my 490 date stamp is not the year 2000, rather 1990. 2000 would be 4900. The tires have lots of tread but are showing some beginning cracking between the treads, so out they go. With only two wheels I'm not taking a chance on old rubber.
The local tire guru suggested using a 225/75R15 instead of the 205's. 28.5 inches high rather than 27.5 and 8.3 wide instead of 7.8. But 2540 lbs instead of 1820. 205's are C while 225's come in D's. I'm working on finishing an order for a new 3500lb axel from Andy and it sure seems the 225's would work fine with a increased axel angle.
Are any of you late 66-68 Caravel owners running 225's. Also what it the wheel size you are using.
Over59 is offline   Reply With Quote
Old 03-16-2004, 04:33 PM   #2
Zed2's Avatar
2007 25' Safari FB SE
Plano , Texas
Tire 6.70x15 LT (8ply)
Do not use a radial, use a bias ply.
Keith
Zed2 is offline   Reply With Quote
Old 03-16-2004, 04:45 PM   #3
Retired.
. , At Large
What size tires are on your trailer now? If you have the 7.00/15 tires, the 225's are the closest radial size to that.
Just make sure of your weight rating and inflation pressures.
Old 03-16-2004, 05:06 PM   #4
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Mine is running 205/75R15, which is what the previous owner had on it. I can't imagine going any bigger in either direction, it's such a tight fit in the wheelwell as is. It was such a bear to wriggle it out for the bearing maintenance.
I haven't read up on weight ratings, I assume that means each tire is rated to carry 1820 lbs? Because that would still exceed the capacity of even the 3500 lb axel if I understand it right. Of course, if you're buying an axel from Andy, just ask him what to do for tires. I'm sure he knows better than anyone - well better than me anyway
Stephanie
Old 03-16-2004, 05:24 PM   #5
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
I recently ran accross a set of rims that are alloy and rated 2540lb. That's what I'm going with.
I'll also be running "D" rated tires, probably the Good Years.
http://www.rjays.com/Wheels/hi-spec-wheels-01.htm
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 03-16-2004, 06:36 PM   #6
whistler's Avatar
225/75-15's
That's the size tires that I run on mine. Don't know if they were the original size, the PO put them on. They do not give you alot of clearence room but with over 3000 miles logged on them I have never had a problem. Running empty or loaded everything has been fine. They are a 8 ply trailer tire and I am running with the original axle. (since it still has the correct angle)
whistler
whistler is offline   Reply With Quote
Old 03-16-2004, 07:37 PM   #7
Over59's Avatar
Images: 37
Zed
Why not radials trailer tires?
Old 03-16-2004, 07:41 PM   #8
Over59's Avatar
Images: 37
Toaster
Those are awful pretty wheels for so old a trailer.
Which ones you going for. I like the directional ones... make me look fast.
Do you have the 5 5.5 hubs?
Old 03-16-2004, 08:05 PM   #9
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
bias ply vs. radial
The following info is from this TRAILER TIRE ARTICLE:
Bias Ply - Poly or Nylon cords crisscross the tire from bead to bead with the same number of ply at both tread and sidewalls, providing stiffer sidewalls and more resistance to sway.
Radial - Radial Plies run at right angles straight across the tire from bead to bead with belts (usually steel wire) under the tread. This provides excellent traction holding tread to road during swerving or turning. These are very important features for controlling a car or truck, but the flexible sidewalls of this type of tire may aggravate trailer sway problems when this type of tire is installed on a trailer.
Rog
Rog0525 is offline   Reply With Quote
Old 03-16-2004, 08:11 PM   #10
whistler's Avatar
radial tires
Just have a semi pass you going 80 with radial tires on your trailer and you never use them again.
whistler
Old 03-16-2004, 08:49 PM   #11
Over59's Avatar
Images: 37
Now you all have made it complicated again. First off at 80 the semi isn't going to be passing me very often. But I do see your logic.
I haven't had much of a semi problem so far. I think the truck tires may be as much an issue as the trailer, esp since there are four of them. I have those German tire on the truck.
Old 03-17-2004, 10:41 AM   #12
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Aren't the Goodyear Marathons radials?
Stephanie
Old 03-17-2004, 11:35 AM   #13
Rog0525's Avatar
Images: 11
Good point Steph. I have GY ST225/75/R15's on my Caravel because that's what I saw recommended on other threads.
Now it seems that ST225/75/D15 would be the preferred tire.
Does anyone know what Airstream equips the new trailers with?
Rog
Old 03-17-2004, 11:40 AM   #14
Zed2's Avatar
Plano , Texas
I was in your shoes last year, so here is what I'd recommend,
-Call Cordovan Tires at 1-800-238-6469 - see web site:
http://www.cordovantires.com/index_1.html
-Ask about availibility of the
Powerking Premium Super BF34 (6 ply)
(As of today, my 6.70x15 are available (but not listed on the web site.)
-Ask for the name of a distributor in your area.
-Call distributor and ask for name of a local dealer who can order the tire.
(Neither the distributor or dealer will have ever heard of this tire, but who cares as long as the fitment is correct.)
I paid $59.00 for the each tire last year.
There are other bias plys around, but this is the easiest one to get. (Every tire dealer tries to sell a radial, they don't understand the advantages of the bias ply for a travel trailer.)
Regards,
Keith
Old 03-17-2004, 11:57 AM   #15
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
I've got to say I don't think I'm going to go out of my way to switch to bias ply tires. In my case anyway, we're talking about a very small trailer, a very big tow vehicle, and friction sway control on the hitch. We had many situations last year where huge semis and motorhomes blew by us and we had not the slightest bit of sway from the trailer.
I am looking to get a new set of tires for our big trip in two months, but I think I'll stick with just replacing with what it's got on it now. Also, last year I bought a new spare, and it's a radial Marathon. I wouldn't want to be forced to mix and match if I got a flat.
Stephanie
Old 03-17-2004, 07:27 PM   #16
Over59's Avatar
Images: 37
Wheel center hub?
Sure haven't standardize wheels have they. I'm looking at wheels and measuring mine and we have 5 on 4.5 15 inch 5 inch wheels. Thats the easy part. The center hub is slightly less than 2.5 which would seem to be the 2.30 size wheel. Anyone have any prior knowledge about this part.
Old 10-22-2004, 04:38 PM   #17
Just purchased a "68" 17' Caravel. Must completly restore/redo the inside. Would enjoy hearing about your unit (even some pictures) or, I travel to Kelso on occasions and could stop by for a peek. Have very little experience in RV's and fixin them. Your knowledge would be appriciated.
Jerry Cavens
Umatilla, OR
jerrycavens is offline   Reply With Quote
Old 10-22-2004, 07:37 PM   #18
Retired.
. , At Large
The weight rating is per tire, for single-wheel applications. If you have some kind of macho, he-man Airstream with dual wheels per axle, the weight rating per tire is about 10% less, or 90% of 1820, x2, or 3276 pounds per pair, or 6552 pounds per axle . I don't think any of us will have that problem .
Old 10-23-2004, 06:02 AM   #19
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
They will if you ever tow on I-75 in Florida.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 10-24-2004, 06:22 PM   #20
Retired.
. , At Large
Originally Posted by Pick
When do they go that slow???
caravel
