Old 03-17-2004, 11:57 AM   #15
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I've got to say I don't think I'm going to go out of my way to switch to bias ply tires. In my case anyway, we're talking about a very small trailer, a very big tow vehicle, and friction sway control on the hitch. We had many situations last year where huge semis and motorhomes blew by us and we had not the slightest bit of sway from the trailer.
I am looking to get a new set of tires for our big trip in two months, but I think I'll stick with just replacing with what it's got on it now. Also, last year I bought a new spare, and it's a radial Marathon. I wouldn't want to be forced to mix and match if I got a flat.
Stephanie
Old 03-17-2004, 07:27 PM   #16
Over59's Avatar
Putnam , Connecticut
Images: 37
Wheel center hub?
Sure haven't standardize wheels have they. I'm looking at wheels and measuring mine and we have 5 on 4.5 15 inch 5 inch wheels. Thats the easy part. The center hub is slightly less than 2.5 which would seem to be the 2.30 size wheel. Anyone have any prior knowledge about this part.
Over59 is offline   Reply With Quote
Old 10-22-2004, 04:38 PM   #17
Just purchased a "68" 17' Caravel. Must completly restore/redo the inside. Would enjoy hearing about your unit (even some pictures) or, I travel to Kelso on occasions and could stop by for a peek. Have very little experience in RV's and fixin them. Your knowledge would be appriciated.
Jerry Cavens
Umatilla, OR
jerrycavens is offline   Reply With Quote
Old 10-22-2004, 07:37 PM   #18
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by Stefrobrts
I haven't read up on weight ratings, I assume that means each tire is rated to carry 1820 lbs? Because that would still exceed the capacity of even the 3500 lb axel if I understand it right. Of course, if you're buying an axel from Andy, just ask him what to do for tires. I'm sure he knows better than anyone - well better than me anyway
The weight rating is per tire, for single-wheel applications. If you have some kind of macho, he-man Airstream with dual wheels per axle, the weight rating per tire is about 10% less, or 90% of 1820, x2, or 3276 pounds per pair, or 6552 pounds per axle . I don't think any of us will have that problem .
Old 10-23-2004, 06:02 AM   #19
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Over59 wrote:
First off at 80 the semi isn't going to be passing me very often.
They will if you ever tow on I-75 in Florida.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 10-24-2004, 06:22 PM   #20
Well Preserved
1993 21' Sovereign
Originally Posted by Pick
When do they go that slow???
Old 04-06-2010, 04:01 PM   #21
rgesch's Avatar
1956 26' Cruiser/Overlander
1967 17' Caravel
Newport , New Hampshire
Images: 18
A tire related question...
I want to replace my hub caps on the 1967 Caravel. I have the originals but they were so damaged my Dad thought it would be too expensive to re-chrome them so he just painted them black. It looks weird.
I notice Vintage Airstream has two types and from reading the thread I can only assume mine is the same size 15.
Has anyone replaced their hubcaps and what did you get and where?
Robin
KB1UFH
KB1UFI
"Reality Is The Leading Cause Of Stress"
"There are only five great men in the world and three of them are hamburgers."
rgesch is offline   Reply With Quote
Old 01-24-2011, 09:26 AM   #22
1967 17' Caravel
Saratoga Springs , New York
I notice Vintage Airstream has two types and from reading the thread I can only assume mine is the same size 15”.
Robin
We replaced both the wheels and chrome hub caps on our 67 Caravel with ones purchased from Vintage Trailer Supply in Vermont. They are 15" and look great! The price was very reasonable and arrived very quickly.
Sent from my iPad using AIR Forums
JEB_LSB is offline   Reply With Quote
caravel
