Old 06-25-2015, 10:51 AM   #85
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
Floor
I decided to see if vinyl plank flooring would work here. A bit heavier than ordinary vinyl flooring but it has a nice effect. Wheel house covers still useable.
ID:	241569   Click image for larger version
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 07-14-2015, 08:14 PM   #86
1968 24' Tradewind
1967 17' Caravel
Northborough , Massachusetts
Looks good...
I recently used a cork flooring from Lumber Liquidators and I like it slightly more than the vinyl ... it is warmer to walk on with bare feet and cushions better... though dings easier.
I find most of those old wheel well covers too brittle to even attempt to use.
I bought a cheap bending brake on Amazon or Ebay and then buy inexpensive aluminum or galvanized sheet metal (thin) and remake ones that won't break down. I put 1" foam insulation board (R8) in between to keep it temperate and quiet. I can even match the angle with a little extra work. I just use 1/8" rivets to button all the pieces together and it matches the original in size and intent.
Very little extra weight... and it creates one more metal layer in the event of a blowout that try's to get inside. On that note think hard about adding wheel monitors to your trailer and tow rig.
Chuck
cwbiii is offline   Reply With Quote
Old 07-15-2015, 08:02 AM   #87
Argonaut20's Avatar
1966 17' Caravel
I was lucky in that the plastic in the wheel house covers was pliable and breaks were minor and weldable. There is a layer of insulation between the covers and the wheelhouses. One drawback to using the old covers was that they were very close to the wheelhouses limiting amount of insulation.
I put a foam under layment down under the vinyl and plan on using throw rugs. That works well in the Argosy.
2006 Toyota Tacoma
Old 07-15-2015, 11:53 AM   #88
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
I repaired our cracked wheel well covers with fiberglass matt and resin. I didn't worry too much about a smooth finish, just tried to fix the cracks. Once everything dried, I spay painted them black. You can't see the repairs from under the cabinets and everything is holding well.
1965 Airstream Caravel, 2003 Ford F150 SuperCrew, 2003 Miata Special Edition, 1993 Miata Black & Tan
Jewel65 is offline   Reply With Quote
Old 07-15-2015, 09:48 PM   #89
Argonaut20's Avatar
1966 17' Caravel
I used resin to seal the door in the shower before I refinished it with epoxy and the visible parts turned out pretty well. I am a way from putting the shower back in or there would be pictures. I thinned the resin down with acetone until it would penetrate the material the door was made of, then used an epoxy gell to smooth the back surface. Hopefully, it won't leak when I regasket it and install.
2006 Toyota Tacoma
Old 03-06-2016, 08:59 PM   #90
Argonaut20's Avatar
1966 17' Caravel
Update
Cabinetry is coming along slowly. Plumbing is coming along, just waiting until I get the kitchen cabinet and counter top in to finish the connections. The vinyl floor hasn't worked well. It can't be free floating (furniture screws into the floor through the vinyl) and it separates at seams when the temperature changes. I haven't decided what to do about that yet, but I really don't want to undo the screws from the wheel wells, back shower/sink, etc. so I can rip out the vinyl floor to put something else in.
I decided to make a dinette for the front rather than replace the gaucho that was there.Seats will be 4" foam with a 3/4" stock panel in the bottom of the seat to set into the base of the dinette. That should keep the seats in place while moving, but make it easy to lift the seat out to access storage under it. Seat backs of 4" foam that will snap onto the back. Lower the table into place between the seats, put the backs down on the table, and it will make a 24" wide bed that is 76" long.
ID:	258284   Click image for larger version
2006 Toyota Tacoma
Old 03-06-2016, 09:04 PM   #91
Argonaut20's Avatar
1966 17' Caravel
Update2
Just some photos of the back in progress. And a shot of the front overhead. I don't have a photo yet of the front window guard I put on, but it looks like a traveling big screen TV.
ID:	258286   Click image for larger version
2006 Toyota Tacoma
Old 03-07-2016, 09:05 PM   #92
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
I really like the woodwork. Looks like mahogany. I thought about vinyl flooring but settled on VCT tile. It gives a nice retro look and is durable. It can be waxed to a nice shine. I would think you could cut around the wheel wells. I'll be following your window guard progress. I am thinking about refurbishing and old original one, but replacing the green fiberglass with something else, maybe some of the big box store smoke roof panels.
Old 03-07-2016, 09:53 PM   #93
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I removed the front gaucho on our '65 Caravel and used the material and re-did the upholstery to make a dinette for two. There is now a larger front shelf with a nice storage unit beneath in the very front, I made four sliding doors for access to the storage. The old TV in the photo has since been replaced with a flat screen.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 03-08-2016, 09:24 AM   #94
Argonaut20's Avatar
1966 17' Caravel
Jewel,
I'm thinking of cutting around the furniture, or cutting away the center strip of the flooring, then laying down the flooring as free floating there and letting the flooring under the furniture do its thing. I did the cabinets out of maple with a dark stain. I cheated on the front window protector. I was going to rebuild the old one with the smoke lexan roofing material. Then I found a center section of the Airstream front guard for $100 with all the hardware. I'll get a picture of it and post.
Jim,
How do you attach the table at the back? The usual swing up arrangement that Airstream uses with clips at the back comes up over the bottom sill of the window. I want to keep the area level there so the cushions will be level to extend the bed width to about 36".
2006 Toyota Tacoma
Old 03-08-2016, 10:18 AM   #95
Argonaut20's Avatar
1966 17' Caravel
Front
Here's the front. Looks like there should be a couple of TV knobs below the guard.
2006 Toyota Tacoma
Old 03-08-2016, 10:48 AM   #96
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
Or how about a remote control! The window guard looks great! Thanks for posting.
Old 06-25-2016, 03:51 PM   #97
Argonaut20's Avatar
1966 17' Caravel
Off to Tucson to have AC & Fantastic Fan installed + polishing + rear bumper reinstalled. After that, it's time for the cushions and the install on the upper cabinets. Dang! There might be a light at the end of the tunnel. Hope it isn't a train.
2006 Toyota Tacoma
Old 11-03-2017, 07:21 AM   #98
Rancho Palos Verdes , California
Is the tv connected to an outside antennae? Is there any tv outlet anywhere in the Caravel that you’re aware of. Just bought a flatscreen and a portable outside antennae and not sure how to do the cable.
jimca is online now   Reply With Quote
caravel
