Old 11-11-2014, 05:30 PM   #57
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
They are scheduled to arrive here on the 13th so I will sent you some as soon as they arrive I had to use the back or blunt end of a chisel as a bucking bar in the groove of the door frame.
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 11-17-2014, 10:17 AM   #58
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
Street Side
Here's the shot of the street side riveted into place. Now to rivet it into the belly pan. Wheel well opening still to go.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 11-17-2014, 01:47 PM   #59
1966 17' Caravel
Looks real good! I did order the 3/16th rivets and will be sending you some rivets tomorrow. I have to trim the wheel well on the street side and finish the wheel well on the curb side.
Cliff
Old 11-17-2014, 05:46 PM   #60
Argonaut20's Avatar
1966 17' Caravel
How are you doing the trim on the wheel well? I haven't come up with a good method yet. I am going to try heating the (possible) trim as I try to form it, hoping to keep it from breaking. I made relief cuts on the back side but the J part wants to split.
2006 Toyota Tacoma
Old 11-17-2014, 11:05 PM   #61
1966 17' Caravel
I am using a wood relief or template and a torch as recommended by the pros. Since I can possibly screw up peanut butter and jelly I bought more than I would need for errors! They (the pros) said to use the torch only to heat it up enough to bend but not so much that it changes colors so I will let you know how it works.
Cliff
Old 11-18-2014, 03:27 PM   #62
1966 17' Caravel
The 1 inch 3/16 rivets arrived today so will be reinstalling the door hinge with then after adjustment.
Cliff
Old 11-18-2014, 10:07 PM   #63
Argonaut20's Avatar
1966 17' Caravel
I am trying the heat and bend technique, too. An old soldering iron seems to put out enough heat to get the aluminum to move, but we will see about fit when it comes to bending and riveting into place.
Patched the water fill area today and I think I will use a marine type water fill rather than the aluminum neck and cap. I think the original fill and cap corroded together sometime in the past and people trying to get the cap off tore the mounting area up pretty badly.
2006 Toyota Tacoma
Old 11-19-2014, 09:50 PM   #64
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Have you guys read Franks Trailer works description on how he did his moulding install? He puts out a bunch of really helpful entertaining info on his blog. Check it out if you haven't already.
desertair27 is offline   Reply With Quote
Old 11-20-2014, 03:34 PM   #65
Argonaut20's Avatar
1966 17' Caravel
Do you have a link for that molding install?
2006 Toyota Tacoma
Old 11-20-2014, 08:52 PM   #66
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Here's the link to Franks blog,http://frankstrailerworksblog.blogspot.com
I'm reading thru it for the specific trim install. I recommend you all read thru it, lots of great info.
Old 11-26-2014, 11:06 AM   #67
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Here's a little something I found, I think he goes in more depth in another post.
http://frankstrailerworksblog.blogsp...-straight.html
It's at the bottom of the post.
Mike
Old 11-27-2014, 08:42 AM   #68
Argonaut20's Avatar
1966 17' Caravel
Thanks for looking for the posts.
The material Frank uses is much like the factory edge. The idea is to cut relief cuts and heat to form using a template. Then, it is a lot of trial and error until it works as per one of Frank's earlier posts. The fun part is getting the curve at the top of the fender done and then bending to fit the curve below.
2006 Toyota Tacoma
Old 01-20-2015, 08:01 AM   #69
Argonaut20's Avatar
1966 17' Caravel
Got the door off and curb side panel off. I laid the old panel over the new and trimmed to fit. I found that 90 degree angles were not in the Airstream panel playbook. That may explain problems I had with the street side panel - I assumed the panel would be a rectangle and it likely wasn't. We will see if the new panel fits right up today. Photos later...
2006 Toyota Tacoma
Old 01-20-2015, 08:25 AM   #70
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Good luck with your panel install. How did the fender trim install go?
Mike in El Paso
caravel
