Old 10-13-2014, 03:37 PM   #43
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
I was pleased to find that in the $20 VTS reproduction, every piece of the mechanism is an exact replica of the original Philips. The nob of the crank has a slightly different profile than 1968, so I used my old cranks.
The stainless steel cover has a VTS logo, so I used my originals, which better matched the patina and logo of the others.
Last year, I saw original, used, winder/closure mechanisms battled for on eBay, selling for $75 each. $20 to get all new guts is a great deal... And they work like new.
ALUMINUMINUM is offline   Reply With Quote
Old 10-13-2014, 06:29 PM   #44
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
Thanks, Aluminuminum. That's great info.
Skatiero is offline   Reply With Quote
Old 10-13-2014, 09:26 PM   #45
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
The covers on several of the winders/latches on mine are so rusty they aren't recoverable. Deep pits when the rust remover gets through with them. Strangely, the interiors are in pretty good shape with one or two exceptions.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 10-24-2014, 09:11 PM   #46
Argonaut20's Avatar
1966 17' Caravel
I just got the Vulkem 116 to use in the side panel replacement along with gaskets and window catches to cinch down the new window I put in back. I'll be posting pics soon, I hope.
I was surprised to find the channels on the side panels that the interior walls rivet into are anything but parallel to the floor. The neat line of rivets on the side that looks parallel to the window frames - aren't parallel at all. Who knew? It shows the Caravel was built by hand.
2006 Toyota Tacoma
Old 10-25-2014, 03:53 AM   #47
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
After lunch a few beers and a shot or two! Like the aluminum and the thought but the quality or craftsmanship is just not there! Before you say it and I know you will! Yes these trailers have held up for decades but most of them sat still or under a cover of some sort for those decades! Still love them and will fix what I find and make my own screw ups!
Cliff
Yes I said that! Or did I?
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 10-25-2014, 10:32 AM   #48
Argonaut20's Avatar
1966 17' Caravel
I think you have the right of it: a happy lunch, then put the channels in. On the other hand, it is hard to find a trailer as stout as the Airstream. Years ago, I pulled a Globetrotter on many a forest 'road' with nary a problem except for having to put everything back on the shelves when some of the cabinet doors opened on particularly rough roads.
2006 Toyota Tacoma
Old 10-25-2014, 11:04 AM   #49
1966 17' Caravel
Design awesome assembly some have minor problems and some are more what the hell? Think that QC had a fun supervisor!
Cliff
Old 11-06-2014, 09:13 PM   #50
Argonaut20's Avatar
1966 17' Caravel
Progress
Real glass in the rear window and new catches. Drilling the screws out to get the old catches out was not fun.
A shot of the open side of the Caravel after the old side was removed, followed by a shot of the new side tacked into place. The sealant used on the panel was a black tape that reminds me of the 3M caulk used on auto bodies. Still sticky after 40+ years.
ID:	225944   Click image for larger version
2006 Toyota Tacoma
Old 11-07-2014, 02:45 AM   #51
1966 17' Caravel
For me it is the panel on the curb side! You did an awesome job I am hoping that the son in law comes down this weekend to help buck!
Cliff
Old 11-07-2014, 07:01 AM   #52
Argonaut20's Avatar
1966 17' Caravel
My wife and I are hoping to rivet the side in this weekend. I haven't figured out how to form the trim around the edge of the wheel cut out yet. I also learned that it helps to have someone inside the trailer with a piece of wood handy to buck the holes as you drill in the areas where there are unsupported panels that over lap. Lessons every day!
How are you handling the door on the curb side? I have to do that side next.
2006 Toyota Tacoma
Old 11-07-2014, 01:46 PM   #53
1966 17' Caravel
I removed the retaining pin that holds the hinge pin in and sprayed like a can of WD 40 on the hinge pin bought a piece of steel rod smaller than the pin and it has started to move. Have to remove the hinge any way so apart I can replace the pop rivets they used on the hinge also have to fix the door and replace the bolt lock also. Son in law is helping and he is starting to enjoy it! Will post some pictures soon!
Cliff
Old 11-10-2014, 06:53 PM   #54
Argonaut20's Avatar
1966 17' Caravel
Bummer
Got the panel up, checked to see that it hung well on the frame, drilled the rivet holes and used clecos and screws to check the fit. Did the riveting today and wound up with a bulge in the lower part of the panel. There had been a bulge in the old skin forward of the replacement panel with rivets that did not extend to the rib. I don't know if that contributed to the bulge in the replacement, but we did make sure that the rivets all went into the frame. I will see if I can make this work. If not, I guess a re-replacement is in order.
2006 Toyota Tacoma
Old 11-10-2014, 07:01 PM   #55
1966 17' Caravel
Got the panel on the cutting went well but the door rivets are longer then I had so ordered some from granger! If you need some I have plenty just want postage! Needed 20 smallest qty 250!!!!
Cliff
Old 11-11-2014, 07:19 AM   #56
Argonaut20's Avatar
1966 17' Caravel
Glad the panel went well. Save some rivets for me as I will be doing that side sooner or later. I'll PM you in a day or so to get addresses done.
2006 Toyota Tacoma
caravel
