Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Caravel > 1966-68 Caravel
Old 10-15-2003, 07:31 PM   #1
tonyg's Avatar
Caravel floor width
Anyone know the inside floor width of a 1966 caravel airstream. Having trouble repairing a section of flooring
tonyg is offline   Reply With Quote
Old 10-15-2003, 11:11 PM   #2
JMoy's Avatar
1966 17' Caravel
Redmond , Washington
Send a message via AIM to JMoy
I am currently restoring my 66 Caravel. Feel free to send your questions to me.
jerry.moy@comcast.net
JMoy is offline   Reply With Quote
Old 10-16-2003, 07:52 AM   #3
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
I'm in the middle of a body off on a 59 Cravanner. I'm not 100 % sure this width is the same but I think the width of the deck stayed pretty consistant till the Argosy and wide bodies came out. Ours is 88 inches on the nose. That includes the 1.5 inches under the U-Track on each side.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 10-17-2003, 08:48 AM   #4
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
I just installed a Uniclic (like Pergo) floor in my 68 Caravel. It was twice as hard as it should have been, because my hallway does not have a uniform width.
In other words, the hallway is about 3/4" narrower at one end than the other. This is because the side couch isn't installed exactly square with the kitchen cabinets.
In fact, nothing in my Caravel is plumb or square!
-- RL
rluhr is offline   Reply With Quote
Old 10-17-2003, 09:28 AM   #5
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
-- RL
Hmmmmm I'm glad you mentioned that. I will make sure my Wardrobe is square to my Galley when they are reinstalled.
1959 22' Caravanner
Atlanta, GA
Old 10-17-2003, 04:51 PM   #6
tonyg's Avatar
thanks for the replys. After installing a section of flooring in the rear and side of my caravel, the outside skin over the wheel well area is wavy. I think maybe the side is pushed out to far or something is out of measurement.
Old 03-12-2006, 02:17 PM   #7
Peter Luger
1968 17' Caravel
Roxbury , New York
Rl,
So when you installed your your Uniclic flooring did you have to do anything with the drawers under the bench? Also did you run your Uniclic right into the bathroom shower pan or did you use something else in the (small) bathroom floor?
Any chance of a few photos?
Peter
Peter Luger is offline   Reply With Quote
caravel
1966 Caravel - barebones from factory? - restoration brusby 1966-68 Caravel 55 04-12-2012 06:49 AM
Caravel :: 1967 Airstream Caravel youngestmeyn Airstream Registry Discussions 0 11-29-2011 09:31 AM
Caravel :: 1967 Airstream Caravel C Johnson Airstream Registry Discussions 0 08-19-2011 08:31 AM
66 Caravel + Sealand Traveler Lite Toilet cal.caravel Sinks, Showers & Toilets 1 03-17-2011 03:19 PM
