Old 09-11-2006, 10:48 PM   #1
, Alaska
Bathroom water damage? Worth fixing?
Uh-oh, there is a 1966 Caravel for sale. I used to own a '79 A/S motorhome, but I sold it and now I'm considering purchasing the 1966 Caravel. The trailer looks decent in and out, except for the wood damage under the bathroom sink area. I will try to post a picture (which I have never done). I couldn't find wood floor damage anywhere else, but I don't know much about trailers. Is the damage indicitive of a rotten floor throughout the trailer? How would you go about fixing the damage? The trailer looks great otherwise, is it worth $2500 with the floor issue?
Thanks and if I can get the picture to post I'll try to post other pictures.
Curtis-79MH is offline   Reply With Quote
Old 09-11-2006, 11:33 PM   #2
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
Caravel, yes!
Hi,
I would sincerely suggest if the Caravel is intact and the skin (outside body) is in good shape and the inside parts are all there, working or not, it will be snapped up by someone! Floors are always a problem with older Airstreams. Weak spot. Some folks have been lucky and been able to partially replace their floor by a section here and there. We did a complete frame off because all of our floor was rotten.
Take a ice pick or screwdriver and poke around under all the cabinets, etc. to see if it feels soft or spongy. If the spot you have the picture is any indication, it probably needs replacing. But, could be just one place. The entrance by the door is often an indicator when you step in does it feel really solid?
Here is my husband's thread on replacing our floor. It is lengthy, but has lots of pictures. Maybe it will be of help.
http://www.airforums.com/forum...mbi-17925.html
Good luck.
Mrs. NorCal Bambi (traveling in S Tardis)
CaddyGrn is offline   Reply With Quote
Old 09-12-2006, 03:58 AM   #3
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Originally Posted by Curtis-79MH
Attachment 25851Hi,
Doesn't look too bad, I repaired my rear floor, here is a link to my web site
http://www.balrgn.com/Airstream/airs...oject_2004.htm
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 09-12-2006, 10:55 AM   #4
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
There will always be some floor problems at that price point.
Only way to have a perfect floor is to buy one that has been totally restored with photos of the restoration.
But then you will have to add another 0 at the end of the $2,500 you are looking at now.
-Tim
theVAP - Airstream Podcast
Atwood water heater uwe Water Heaters, Filters & Pumps 5 10-03-2009 01:58 AM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
city water inlet valve failure? JohnGalt48 Fresh Water Systems 2 08-01-2002 04:43 PM
Water Hammer melprice Water Heaters, Filters & Pumps 10 07-30-2002 01:10 PM
Replace copper water lines in '61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 06:04 AM
