Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Caravel > 1966-68 Caravel
Old 08-30-2016, 08:59 PM   #1
1967 17' Caravel
Stayton , Oregon
Question Bathroom under sink door 1967 Caravel
We have a 1967 Caravel. Anyone have a good picture of the door and what hinges are used on that door for the fiberglass unit under the bathroom sink? We are stumped on the correct hinges, door and gasket or how that door seals. Some pictures would be much appreciated. We are thinking of making an aluminum door by wrapping aluminum aver a piece of thin plywood but would like to see what else might work. No idea what the original was.
tin twinki is offline   Reply With Quote
Old 08-31-2016, 03:15 PM   #2
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
It is about 3/8 - 1/2 inch board that was epoxied (I think). I took thinned fiberglas resin to better water proof this one, then painted with epoxy paint. Hinges are 1/2 inch offset cabinet hinges and the catch is one offered by VTS, I believe. I got some flexible weatherstripping to seal it. It is self adhesive small bulb type from Home Depot.
ID:	270449   Click image for larger version
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 08-31-2016, 03:38 PM   #3
Dingo Girl's Avatar
1967 17' Caravel
Oak Creek , Colorado
I went and looked at mine. They appear to be the same hinges used on the cabinet doors. Like the ones under the sofa and gaucho. Same plastic latch too.
I'd take a picture but my battery is on deadly E.
Dingo Girl is offline   Reply With Quote
Old 08-31-2016, 05:18 PM   #4
Dingo Girl's Avatar
1967 17' Caravel
Here are pictures. The latch is broken. The last one shows the back side of the latch and catch.
I think there are only two latches in my trailer that were not broken.
Hope this helps.
ID:	270456   Click image for larger version
Old 08-31-2016, 08:33 PM   #5
1967 17' Caravel
Stayton , Oregon
Thank you
To all of the above, thank you the pictures and discriptions were what we needed. We have redone much of the inside and rebuilt couches and other doors but this one was a mystery. Again thank you all.
1967, caravel
mystery leak under bathroom sink --- how to access? monkeydance Fresh Water Systems 0 02-29-2016 10:48 AM
How do I remove leaky sink drain pipe, bathroom sink, 1970 Sovereign NevaH Plumbing - Systems & Fixtures 4 09-14-2015 04:01 PM
Water Damage in Floor Under Bathroom Sink? breezyway Repairing/Replacing Floor &/or Frame 3 11-09-2013 06:42 AM
Leak Under Bathroom Sink ... What to do? pdozanne Plumbing - Systems & Fixtures 4 06-03-2012 11:38 AM
One sink, two sinks, red sink, blue sink? Janet H General Interior Topics 7 07-26-2006 06:17 PM
