Old 03-11-2013, 11:33 PM   #1
1967 17' Caravel
georgetown , Texas
Axle measurements
Hi yall,
Ive got my 67 now gutted. Way better to be bare. Replacing all subfloor this week.
I have a question about axle measurements. From another member who has a 65 she used the following measurements to order her dexter axle.
Dexter "Torflex Axle"
#10 torsion axle 3000lb. cambered (slightly curved)
74.5" Hub face to Hub face.
57.7/8" Outside bracket to Outside bracket.
Reverse orientation, side mount, low profile, brackets.
22.5 degrees down, trailing arm.
Electric brakes
Grease bearings (not EZ-lube or oil)
5 lugs on 4.5" centers.
Would this work on a 67?
Are all the axles on these caravels the same?
How is the 3000 lb axle? vs. 3200 or 3500.
Also, the estimate for the dexter axle is $599, complete with brakes. plus labor $75 per hour. He says it should be an easy replacement, maybe 1-2 hrs. How are these prices?
knishiya is offline   Reply With Quote
Old 03-20-2013, 01:13 PM   #2
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
I hope somebody that has done this before responds here. I think 65-68 should be the same. I haven't done the axle yet, but it's on my list soon. Sounds like a good price, although I would check with Colin Hyde to see his price and he would know if your specs are correct. If his is not much more I would go with his. Otherwise the Dexter should do the job if the specs are right.
1965 Airstream Caravel, 2003 Ford F150 SuperCrew, 2003 Miata Special Edition, 1993 Miata Black & Tan
Jewel65 is offline   Reply With Quote
Old 03-20-2013, 01:46 PM   #3
Originally Posted by knishiya View Post
Hi yall,
Electric brakes
A 1967 what.
What is the lenght.
Why 22 1/2 degrees.
Replacement axles should be upgraded and not put back like it was.
