Old 07-12-2006, 09:08 AM   #1
Member
1967Caravel's Avatar
1967 17' Caravel
Creve Coeur , Missouri
Anyone ever put a new fridge in their Caravel
Has anyone put in a new frige in there caravel and have some pictures of the install or even some direction on how to do it. Or even a suggestion on how to get the power all the way over there. thanks Joe
1967Caravel is offline   Reply With Quote
Old 07-12-2006, 01:14 PM   #2
1966 17' Caravel
Seattle , Washington
Send a message via AIM to kitchenclose
I have this on my To-Do list. I would be interested in knowing too.
I bot a bigger fridge and will need to lift the fridge up a bit to clear the wheel well.
Karen
kitchenclose is offline   Reply With Quote
Old 09-01-2009, 08:42 PM   #3
1966 17' Caravel
sonora , California
I just installed a Dometic DRM2354 3-way reefer in my '66 Caravel and it fit in exactly the same space as the original, tho I had to shave a bit off the door to the cultlery tray above it. Ran the 110 from the AC plug above the sink and the 12V from the pump switch in the same location via conduit to the left and down thru the countertop...
sierratony is offline   Reply With Quote
Old 09-01-2009, 09:10 PM   #4
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I put one in my Caravel a couple years ago. It was smaller than the original, no freezer, so a friend built a little drawer under it to lift it up. We ran the power from the box under the gaucho by going back through the bathroom, under the shower pan, and around through the kitchen cupboard. I wish I had found a bigger one that fit the space, this one is pretty tiny.
Stephanie
Old 09-09-2009, 10:37 AM   #5
Send a message via Yahoo to air66caravel
I installed a new 3 way Dometic a few years ago. There was a great page on vintageairstream.com that I used for reference. The height was perfect but had to do minor trim work to the area between the fridge and the door. I will take pics and find the exact model number if you like. How close are you to KC?
air66caravel is offline   Reply With Quote
Old 09-10-2009, 08:00 AM   #6
link for installing fridge
Here is the link for the page that I used as a reference when I installed my fridge in my 66 Caravel.
VintageAirstream - Refrigerators
Old 09-10-2009, 11:02 AM   #7
Over59's Avatar
Putnam , Connecticut
Images: 37
Been there, done that. I had a 120 outlet on that sied I tapped into and the 12v from the kitchen fan
Over59 is offline   Reply With Quote
caravel
