Old 09-10-2016, 12:08 PM   #1
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
68 caravel gaucho legs keep falling out!
Ok, this may be specific to the mid-60s Caravels, but it has been annoying me for the last 13 years, so I finally decided to see if anyone here has a solution.
The gaucho has a narrow piece of wood along the front edge that it sits on. That piece of wood has holes in it, and you stick the legs, which have pegs in them, into the holes.
Over the years the holes get wore out, and so I drilled smaller holes several years ago, but now they have worn out too.
The end result is every time someone rolls over, a leg falls out, and then you have to get up and stick it back in, get back in bed very carefully, and not roll over again.
Do other people have this problem? What do you do? Any ideas would be welcome.
Stephanie
Old 09-10-2016, 12:45 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My Bambi II was doing that. I used larger/longer screws and hinges to fix the problem.
MICHAEL
Old 09-10-2016, 01:43 PM   #3
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
I can't attach the legs where the holes are, because that piece actually sits on top of the cabinet below it when it's folded up. At least I haven't thought of a way to make it work. You don't have a picture, do you? Do Bambi's have basically the same sort of setup?
Stephanie
Old 09-10-2016, 09:55 PM   #4
Argonaut20's Avatar
1966 17' Caravel
Las Cruces , New Mexico
Is the pull out piece not connected to the gaucho frame? My '66 street side gaucho has a frame that pulls out using what amounts to table extension pieces for the pull out support. There is plywood that the cushion sits on and the legs are attached to the front permanently. Let me look for some drawings or pics of that arrangement. The only thing I could come up with that might help keep the legs in place would be threaded rods on the legs and threaded inserts on the board. Even that might get loose with time, though.
1966 Airstream Caravel
2006 Toyota Tacoma
Argonaut20 is offline   Reply With Quote
Old 09-10-2016, 10:05 PM   #5
Argonaut20's Avatar
1966 17' Caravel
Gaucho rebuild
Here is a picture of my street side gaucho as I was rebuilding it. I followed the original structure plan. It is extended so you can see the table extension pieces that support the extension. Plywood will be sewn into the seat back so there will be support for the cushion next to the wall when it is made into a bed. You can also see the legs at the end of the front board.
ID:	271417   Click image for larger version
2006 Toyota Tacoma
Old 09-11-2016, 05:08 PM   #6
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Hmm, that is completely different from mine. On mine the entire cushion just sits on the cabinet frame below it. There's no sliding mechanism.
I kind of like the idea of threaded inserts/pegs on the legs. Maybe something like that would do the trick.
Stephanie
Old 09-11-2016, 09:00 PM   #7
Argonaut20's Avatar
1966 17' Caravel
Do a search on Amazon for threaded inserts to see some examples. Some might fit the holes you already have in the frame and a 1/4 inch bolt size should keep the legs attached.
2006 Toyota Tacoma
Old 05-22-2017, 06:43 PM   #8
Doubleup's Avatar
1968 17' Caravel
Regina , Saskatchewan
My 68 didn't come with any legs. I've been pulling out the drawers and setting that leading strip against the front edge of the drawer. Now I'm going to have to check for leg holes...learn something everyday.
Doubleup is offline   Reply With Quote
Old 05-23-2017, 11:13 PM   #9
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
You know, I don't know why I never thought of just setting it on the drawers - they look pretty sturdy...
Stephanie
caravel
Gaucho Extension! Flip down legs robwok Upholstery, Blinds, Walls & Interior Finishes 9 08-25-2015 09:01 AM
How to keep toiletries from falling out? karenjude General Repair Forum 2 05-29-2015 01:25 PM
Lenses keep falling out ! %$$##@##!@! Phantom Lights - Interior & Exterior 8 01-21-2009 08:06 AM
What do the Gaucho Legs look like? hellokitty General Interior Topics 13 03-17-2008 01:28 PM
Latches Keep Falling Apart flyfisher Doors & Locks 8 06-03-2005 08:39 AM
