Old 02-26-2011, 03:37 PM   #1
1967 17' Caravel
2007 27' Safari FB SE
Landenberg , Pennsylvania
'67 Caravel Airconditioner recommendation
Hi everyone. I'm almost finished with my one year Caravel restoration. I have the polishing to do and an AC to get running or replace. I'll try to find someone to repair the original Armstrong AC. The motor runs, but there is no cool air. In case I can't get it repaired can you save me some time and tell me the best AC to buy and the best size.
I believe I've heard before that the 11,000 btu would be best, but what kind. The Penguin, the Brisk or what?
I appreciate your help.
vonzellen is offline   Reply With Quote
Old 11-01-2011, 10:46 AM   #2
jerbear315's Avatar
1966 17' Caravel
College Station , Texas
Images: 22
Did anyone respond to this? A/C is a priority in Texas. Would like a low profile, but was told it would not work with Caravel...
Jerri again!
jerbear315 is offline   Reply With Quote
Old 11-01-2011, 10:50 AM   #3
Jerri again!
The profile of the AC has nothing to do with what trailer it fits on.
Old 11-01-2011, 11:54 AM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I have some experience here..
I used a low profile Carrier on both my Caravels and the Flying Cloud, and the 21 ft. 94 Sovereign. As Andy said...the profile means nothing to the fit. (There is a small interior unit fit problem with the 94.) In Texas I have found that the 15000 is the only way to go and be comfortable. The 13000 just does not have the "umpfff" needed. If you don't get in a hurry you can still find a Carrier LP in stock at some locations...and they show up at places like Colaws.
caravel
1966 Caravel - barebones from factory? - restoration brusby 1966-68 Caravel 55 04-12-2012 06:49 AM
Caravel :: 1967 Airstream Caravel C Johnson Airstream Registry Discussions 0 08-19-2011 08:31 AM
66 Caravel + Sealand Traveler Lite Toilet cal.caravel Sinks, Showers & Toilets 1 03-17-2011 03:19 PM
67 Caravel Help: to sway or not to sway vonzellen Hitches, Couplers & Balls 15 01-26-2011 05:07 PM
