Old 05-28-2013, 12:39 PM   #99
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
I have been playing with the fridge vent (inside) and I think that I am going to make a template and then a mold and hopefully a fiberglass replacement. Same size and shape just different material and color. A little difficult but not impossible and better than what left of the original!
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 05-28-2013, 02:16 PM   #100
Baltimore , Maryland
You can get an aluminum one via Out of Doors Mart. It is slightly bigger so you will need to fill the old holes. I use buck rivets to do this. The vent cover polishes like a dream and looks totally original. The filled in holes cannot be seen under the new vent cover. Just a suggestion.
Old 05-28-2013, 05:02 PM   #101
GAStreamin's Avatar
2012 25' Flying Cloud
Moultrie , Georgia
I am making one out aluminum. We'll see how it turns out. Well, the welder is making one.
GAStreamin is offline   Reply With Quote
Old 05-28-2013, 05:16 PM   #102
1966 17' Caravel
62 I was referring to the plastic one on the inside that falls apart when you remove it. But yes I am getting one from out of doors mart for the outside and was wondering about the mounting over the old holes. And that sounds better than cutting it. Thanks
Old 05-28-2013, 05:20 PM   #103
1966 17' Caravel
I thought about aluminum for the inside but then looked at the mirror in the guest bathroom and decided that the grandchildren have wonderful small hand prints just not for continuous wiping of fingerprints from the aluminum. We are going with fiberglass and what ever color she decides will be mixed into the jell coat.
Old 05-28-2013, 05:21 PM   #104
GAStreamin's Avatar
Moultrie , Georgia
Good thinking! I will have the same issue. I didn't think of that!
Old 05-28-2013, 05:23 PM   #105
1966 17' Caravel
Will let you know how the mold thing goes if it works than you can barrow it and make one.
Old 05-28-2013, 05:26 PM   #106
1966 17' Caravel
Feels good removed the antenna and cut wood for braces and if it continues to go well she'll off by Friday! Tv antenna is not going back on! Keeping the radio antenna so we can have some music in the faraday cage!
Old 05-28-2013, 06:00 PM   #107
My mistake... If you do make a mold, you will create a nice little side business for yourself.
Old 05-28-2013, 08:14 PM   #108
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
I can only guess that Airstream had a few different molds over the years because a few summers ago I saw 4 of these vents sitting side by side, all off mid 60's units and all had a significantly different arch to them. I've also heard some of the vendors have made some repros but that they either fit awesome or aweful depending on the shape of the walls. on the day the trailer was built.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is online now   Reply With Quote
Old 05-28-2013, 09:56 PM   #109
1966 17' Caravel
My endcaps and shower unit are fiber glass and I have seen several of the plastic scoops that are cracked and broken mainly because plastic has a much shorter life than fiberglass. The only benifit I can see with plastic is the fact that it is that it can be molded and fitted with heat. Airstream used heating to fit these scoops because airstreams all very in shape and curves. The fiberglass while rigid if too thick will not conform to every caravel let along every Airstream. If I used plastic then a heat gun would provide for a costum fit but i have no experience with plastic. may try and see if the I can mold the plastic to the form with a heat gun.. then could fit any airstream for about 30 years of use.
Old 05-28-2013, 09:58 PM   #110
1966 17' Caravel
That was vary and custom fit!! still making a fiberglass scoop first.
Old 05-29-2013, 04:28 PM   #111
1966 17' Caravel
Removed the rub rail and one of the wheel well patches and took pic just got to put them on the thumb nail. To post them.
Old 05-30-2013, 03:33 PM   #112
1966 17' Caravel
All braced and ready for lift off! One I drill all of the remaining buck rivets!
1966, 1966 caravel, caravel
