Old 06-02-2013, 06:33 PM   #141
reinergirl's Avatar
Hollis , New Hampshire
Gosh, I'm starting to feel like Debbie Downer on this thread, but I wouldn't cover it! Most people find that tarps and such do way more damage to the skin than the weather would. Those skins scratch really easily. I've seen flapping tarp damage and its not pretty (or fixable)....And who cares if it leaks right now?
reinergirl is offline   Reply With Quote
Old 06-02-2013, 06:40 PM   #142
Baltimore , Maryland
What Debbie said for sure!!!! A tarp will cause you so much damage in just a short time. Listen to what Debbie just said and get rid of that tarp.
Oh yeah, 8 hidden rivets today and how many before?
Old 06-02-2013, 06:44 PM   #143
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
It's all good Shelly I covered the trailer not the upper shell would not do that for the reasons you stated. Until I get the wood off for use as a template I need to keep it dry and it is going to rain during the day tomorrow then it will be uncovered for many measurements! Important I hear to make it all fit right when you put it back together!
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 06-02-2013, 06:46 PM   #144
1966 17' Caravel
Oh and by the way only covered the wood and with plastic not really a tarp.
Old 06-04-2013, 06:52 PM   #145
1966 17' Caravel
Okay today I have made many measurements of the frame with the u channel and old floor still on as recommended by a few of the pros on the forums and now I am ready to take the floor belly pan off And get the frame repaired. Pics with progress.
Old 06-04-2013, 07:19 PM   #146
make a template of the c channel so you can get it correct when you put it back together.
template to the inside edge of the channel.
Then add on for the c channel. No guessing this way.
Old 06-05-2013, 01:20 AM   #147
1966 17' Caravel
Template the channel!? I did not even think of that! Thank you I will do that before I take it off.
Cliff
Old 06-05-2013, 03:02 AM   #148
if any wood is rotted you have to guess. This way there is zero guessing. In earlier eras (than yours)the production was much more hand built and often the curve is slightly different from one side to the other. Sometimes is is shifted ever so lightly too. Doing the template recreates exactly what is there. Generally the floor is 1/8" less than the C channel is wide or the channel will hang over by 1/8".
BTW, a 1967 Caravel came into the cue yesterday. It will need an entire new floor also.
Old 06-06-2013, 12:28 PM   #149
1966 17' Caravel
Storms comming so not much done this week! Got the shell strapped down and the frame covered with plastic.
Old 06-06-2013, 02:07 PM   #150
GAStreamin's Avatar
2012 25' Flying Cloud
Moultrie , Georgia
Same here!
GAStreamin is offline   Reply With Quote
Old 06-07-2013, 06:29 AM   #151
1966 17' Caravel
Okay this is my weekend so how about some sunshine!
Old 06-07-2013, 04:40 PM   #152
1966 17' Caravel
Done with all the hype no damage cuz just a normal tropical storm, it was I guess a just reason to panic the young and get the granddaughter up at 3am! Will get something done this weekend!
Old 06-09-2013, 02:45 PM   #153
1966 17' Caravel
The forecast today was rain so I pulled the floor from the rear and since it should be the worst of it as far as the frame goes it seemed like a good place to start! Not too bad for a 47 year old frame! Will take some pictures this week.
Old 06-09-2013, 02:47 PM   #154
GAStreamin's Avatar
Moultrie , Georgia
I was the same. I was pleased with my frame considering the age. It shouldn't be too bad. If mine was not a rear bath, it would be even easier to get repaired. Rained here most of the day yesterday, and today it is suppose to rain, but not yet.
1966, 1966 caravel, caravel
