Old 05-31-2013, 06:22 PM   #127
reinergirl's Avatar
Hollis , New Hampshire
This is how I remove my solid rivets. Works great, if a bit more time consuming,
Removing Solid Rivets - Matronics
I use two drills to avoid switching the bits. This way I very rarely get any damage to the original hole. The ones around the door I did use a chisel on.
reinergirl is offline   Reply With Quote
Old 05-31-2013, 06:50 PM   #128
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
Thanks Shelly I will try this it beats cussing and bleeding!
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 06-01-2013, 06:29 AM   #129
Baltimore , Maryland
You are getting some good advice, however, I just drill them free hand. No punch, no multistep process. The bit I use is a sharp 1/8". I drill right into the center and move on. It generally takes less than 15 seconds. The new rivet is 5/32" so you have lots of room for slop. The new rivet hole is a #21 which is 10 bit sizes larger than the #31 hole you are removing the rivet from. You are not reinstalling 1/8" rivets so preserving the exact same hole is just overkill. Drill that hole and move on. There is no need to stress over this.
Old 06-01-2013, 07:21 AM   #130
GAStreamin's Avatar
2012 25' Flying Cloud
Moultrie , Georgia
Exact same bit size I used.
GAStreamin is offline   Reply With Quote
Old 06-01-2013, 10:57 AM   #131
There are 3 different sizes of rivets, that you may need to remove.
1/8", 5/32", and 3/16 inch.
The correct number drill bits to use are # 30, # 21 and # 11.
# 30 drill bit is .1285 for .125 rivets (1/8")
# 21 drill bit is .159 for .15625 rivets (5/32")
# 11 drill bit is .191 for .1875 rivets. (3/16")
Old 06-01-2013, 11:04 AM   #132
1966 17' Caravel
I will let you know how it goes I am going to get some new bits (2 bits remaining) still having fun but need to use the better bits! Got to say I have learned a lot about aluminum after thinking that I was experienced with it working on several military aluminum projects. As they say learn something new every day!
Old 06-01-2013, 11:07 AM   #133
1966 17' Caravel
Thanks Andy better late than never and I have yet to order the black tank but I do have your number and I will hopefully be at that point soon!
Old 06-01-2013, 03:58 PM   #134
1966 17' Caravel
Alright much progress 30 buck rivets and only 1 drill bit! Got another 40 or so then lift off!
Old 06-01-2013, 04:28 PM   #135
GAStreamin's Avatar
Moultrie , Georgia
Great job!!!!
Old 06-02-2013, 04:51 PM   #136
1966 17' Caravel
some major progress!
Today we removed 8 hidden rivets and only 2 of those with a chissel! then we cleared the dead ends eith a punch and yes we popped the shell! I still got my nappy (gotta work tonight)! gonna have to slow down on the pics will run out of room! the trailer now sits in the driveway and the shell is lowered and will be tied down tomorrow but the bulk of the work will now concentrate on the trailer! What a workout!
cliff
ID:	187220   Click image for larger version
ID:	187222   Click image for larger version
ID:	187224   Click image for larger version
ID:	187226   Click image for larger version
Old 06-02-2013, 04:53 PM   #137
1966 17' Caravel
Hate it when i post a pic twice!
Old 06-02-2013, 04:54 PM   #138
reinergirl's Avatar
Congrats! Please make sure you tie down the shell as a stiff wind can cause it to take flight!
Old 06-02-2013, 05:04 PM   #139
GAStreamin's Avatar
Moultrie , Georgia
Hey Cliff! We are so excited! Major progress for you! My husband and I looked at the pics and we were proud of your progress. Tom said your floor looks like ours does. It looks real good!
Old 06-02-2013, 06:16 PM   #140
1966 17' Caravel
Thank you I have the trailer covered (storms on Monday ) and will be strapping the shell down with the mobile home anchors. The wind doesnot get too bad in our court but not going to take any chances! We shooting for shell back on in three weeks. Once the shell is on then we will replace the curb side panel. Again thank you it feels good to get that done.
1966, 1966 caravel, caravel
